Question about Sharp AR-507 Copier
Ar 507 F2-37 How to fix?
19 years fixing and still at it. Do I clean the drum and sensor? Thanks guys and girls for your help. Regards, Rob
  • upperfuser4 Oct 23, 2008
    Hi, Thank you very much for your assistance. Is there anyway I can do the adjustments? I am pretty handy. Regards, Rob
  • Sharp Master
  • 2,794 Answers
ID pattern reading error.  This time its in the optics section.  It should be looked at by a technician because there are timing adjustments that need to be done.  If they are not done correctly you will get very poor copy results.
Posted on Oct 22, 2008
  • Tim Babcock
    Tim Babcock Oct 23, 2008
    There actually is a measuring system that is used on the optics.  You could check on and get hold of a Sharp technician who might know if anything can be done on your end to fix it.
    It's a free site.  It's like only it specifically deals with copiers.  There are technicians from each copier line available to assist you.
Clear sharp F2-31 code
Clean image density sensor on the drum unit and make sure the blade is cleaning the drum.
Oct 01, 2009 | Sharp AR-507 Copier
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Sharp AR 507 has a code L3-00 Scanner will not retun home in time
It could be the Mirror Home Position Sensor malfunction, it's located at the upper left section of the upper frame, if the copy lamp is in its home position, there's a lever/part of the copy lamp that actuated this photo sensor. Try clean that tiny gap with a hand blower, if L3 still occur then you should change it.
Mar 11, 2009 | Sharp AR-507 Copier
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
Manufacturing DAte Of Sharp AR-507
that copier was in production between 1998 and 2000, dont quote me but i think it is 9/9/2000
Jan 31, 2008 | Sharp AR-507 Copier
Sharp Ar-507
An F2 code depending on the secondary code is related to the toner or drum.
F2 00 Toner control sensor open 22 LCC 24v power abnormality
02 Toner motor connector unconnected 50 Non supported option connection (Desk Unit)
31 Process control trouble (Drum surface reflection) 51 Non supported option connection (LCC Unit)
32 Process control trouble (Drum Mark) U7 00 RIC communication trouble
37 Drum marking sensor gain adjustment error U9 00 Operation control communication trouble (ICU)
39 Process thermistor breakdown
Jan 02, 2008 | Sharp AR-507 Copier
Sharp AR-507 Copier Logo
163 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
