Question about Cobra Mr F75b Marine Vhf Radio Fixed Mount 25watt
Transmits but does not Receive
I need help trouble shooting my new marine radio and antenna; it appears that I transmit but can not receive calls. I can hear some of the weather channels but that's all. Components are:
  • Antenna is a DIGITAL 528-VW VHF 4FT 4.5DB by Digital Antenna
  • Radio is a COBRA MR F75 VHF W/ DSC25 WATT
Installation was pretty much plug and play not having to cut or splice the antenna coax using the factory installed connector and the power was connected by wing nuts on top of battery.
I have talked with customer support representatives from both companies and they each suggest the the problem is with the other unit. i need to know how to pinpoint the problem; is it installation, radio or antenna? Any help would be greatly appreciated.
thanks keith
  • 35 Answers
Did you check to see if it's switched on US and not on International?.
Posted on Jul 13, 2013
    Scholar:
  • 157 Answers
Check your microphone by swapping with another duplicate. If no differance, you will need a SWR meter (standing wave ratio) to find the culprit. It attaches in line of the coax and determinds power out and reflected power. The reading should be 25 watts foward and max of 1 reflected.
Posted on Oct 28, 2008
I have a uniden vhf radio that transmits but won't receive
send it for repair
Uniden - Online Repair Form - Uniden Repair Center - Uniden Americahttps://repair.uniden.com/repairInstruct.cfmRepair Procedure -Brand New Products. Marine Radios=3yr Warranty, Scanner Radios=1yr Warranty. GPS System=1yr Warranty, Digital Camera=1yr. Warranty.
uniden vhf radio Google Search
Jun 24, 2017 | Uniden Radio Communications
Cobra radio transmits but won't receive
Check coax continuity with a VOM/ continuity tester. Make sure the braid and center conductor aren't touching. OR, put the radio on an antenna system that is known to be working and see if receive works. If after these tests you still don't hear anything, You may need to talk to a repair technician.
Aug 25, 2016 | Cobra Radio Communications
I can't transmit on my rs82 radio although the station can receive
Simrad RS82. Ok, can you switch to 1 watt and see if it transmits on low power? If it does, check all wiring and your power source (battery or power supply) for enough voltage. Marine radios often get corrosion on connections. Later, check your external antenna and connectors. Of course, you can never transmit on the pre programmed weather channels.
Oct 01, 2015 | Radio Communications
My Yaesu Ft-857 transmits ok on 2 meter. But the receive only work sometime?
Sounds like a bad receiver in the radio.
Have you checked the VSWR of you antenna system?
Did it ever work with the current setup?
If so has anything changed with the programming of the radio or the antenna system?
Does 70cm work OK?
Are you sure menu item 080 is set to "SQL" and not "RF-GAIN"?
Are you sure the receiver is not programmed for tone squelch?
Either of those settings could cause receive problems if not used properly.
Sep 26, 2014 | Yaesu FT-857D transceiver
My radio will not transmitt but it receives just fine
Most problems with radios that receive but do not transmit are antenna or antenna wire/connector issues. It's easy to receive with a marginal antenna but transmitting requires a good working antenna. If you have a SWR meter or can get your hands on one, install it in line with the antenna and test for reflected power. Of course, make sure your TX light comes on when you depress the mic switch. If not, switch mic and try again.
Hope this is helpful! Reply if u can.
Oct 06, 2012 | Uniden Solara DSC VHF Marine Radio
My radio transmits fine. Until recently it received fine. Now it transmits but it does not receive. I've played with the squelch and volume. No luck. Can you advise.
Your finals are fried. Take it to a shop and they will fix the finals. Before you do that be sure to put in an extension speaker just to be sure. Most CB shops are inexpensive.
Aug 29, 2011 | Uniden Solara DSC VHF Marine Radio
My radio receives the wx stations fine, it transmits fine but it will not receive when switched to cb, I have tryed ex speaker, still nothing. mete wont move in receive mode, but when keyed the tx is over...
Here is the list just scratching the surface.
  • Bad antenna
  • Bad coax cable ......grounding externally or internally with shield.
  • Bad/poor ground for antenna..........door to body, painted parts when mounted elsewhere.
  • Antenna installed incorrectly. Nylon grommet must insulate antenna from contact with mounting bracket. Coaxial connector must have contact with bracket for grounding.
Jul 02, 2011 | Uniden Bearcat Pro PC68LTW 40-Channels...
Radio transmits at close distance only.
If the radio device has a variable strength setting for transmission, set it at the higher value... for example 5 watt as opposed to 1 watt. Also, ensure you have a quality antenna. Radio signals are usually line of sight signals, so if there are many obstructions between the radio antenna and the receiver/listener, strength of signal can be affected.
Mar 11, 2011 | Cobra Boating
Cobra Mr F75b Marine Vhf Radio Fixed Mount 25watt Logo
714 people viewed this question
Top Cobra Boating Experts
RFburns
Level 1 Expert
Electro Med Services...
Are you a Cobra Boating Expert? Answer questions, earn points and help others
