Question about Refrigerators
Fridgidaire with crushed ice problem
Sorry - got called away - back now and still dealing with side by side that makes ice and gives water but doesn't crush ice. You asked if front panel comes off - it does. I also pulled the next panel off and saw wires but stopped because I clearly don't what to do at this point.
Can you continue the vein of questioning and tell me what I'm looking for to fix this? Is it possible for me to fix or should I have an expert at this point?
    Sergeant:
  • 409 Answers
It sounds like you should have a qualified technician to come and take a look if you have never opened the ice dispenser before, due to the fact that you have electrical and water line in almost the same place and that could be dangerous.
call a technician and you can have a look when he's there to get more exposure to these types of problems.
thanks again for letting me help.
Posted on Oct 22, 2008
My side b side fridgidaire will only make cube ice now not crushed
fridgidaire makes cubed ice but crushes ice. could be push button on door, mechanism that crushes ice, if not mechanically inclined please call refrigeration tech to check out.
Apr 10, 2015 | Frigidaire FRS3R5EMB Side by Side...
The icemaker on my older kenmore side by side refrigerator doesn't make ice?
What you are probably dealing with is the little valve called (Water Valve) on the back of side of the refrigerator usually down low towards the bottom right hand side if you are facing the back of unit. Its the part that the water line run into and also will be a water line coming out of it going up the back of the fridge and goes thru into the freezer to the Ice maker in the freezer
Aug 08, 2012 | Kenmore Refrigerators
My fridgidaire side by side only dispenses crushed ice even it the setting is at cube. What is the problem
there is a c clip on the solenoid that pulls the rod up to change from cube to crushed its behind the plate on the back where drive motor is
Sep 10, 2011 | Frigidaire FRS26R4A Side by Side...
My side by side refrigerator has an in the door ice and water dispenser that will no longer drop cubes - just crushed ice. What's the deal?
Hello. Here is the fix for your problem. Remove all of the ice and use a blow dryer to dry all of the surfaces well. Then spray the surfaces with PAM no stick cooking spray. This will renew the food safe no stick surfaces in your icemaker and give you months of service. Regards, Joe
Nov 18, 2009 | LG LSC26905TT Side by Side Refrigerator
The ice maker on my Fridgidaire will only give crushed ice, even though we've never pushed that button. We only want cubes.
check to see if your ice solenoid on the rear of the ice maker bracket is seized up with ice. if so you can remove this and run warm water over to unseize solenoid. remove ice bucket and u should be able to see the solenoid close to rear wall. it is attached to the metal bracket that holds the ice bucket in place. usually two quarter in screws holds it in place
Jun 21, 2009 | Electrolux Refrigerators
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Ice dispenser crushes ice when cube is pushed
the little gate/door, is a common issue, its a solenoid htat either burns out, or merelt freezes over. if you put your finger into where teh "shepard hook" supposed otgo, can you freely lift it ip and down???i would assum not, .the entire ***,bly lifts out of freezer( remove 2 1/4 inch scres under each corner and diconnect apower plug behind the ice maker. from ther you can try to defrost teh piston,if not rplace it.
Jan 02, 2009 | Frigidaire GLRS267ZA Side by Side...
Ice maker stuck on ''crushed'' ice
i think it's simpler than that. there's a plastic gate that snaps UP for cubed and DOWN for crushed.
When you remove the tray, set it to CRUSHED, BEFORE putting the tray back in place.
Nov 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
