Ru-32fc30 lg has no color on all inputs except component and the menus.this tv uses vct3804b jungle and also has digital comb filter/ did not come with pip/
5 Suggested Answers
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
ctf1800
  • 4402 Answers
SOURCE: No signal on main tuner
can you connect comcast to another tv that should tell you if it's the tv tuner or cable company.
Posted on Jan 31, 2008
video-tek
  • 150 Answers
SOURCE: No video from any input. No menus on screen.
No picture or OSD (menu) means your tubes are not lit which means high voltage failure of some sort, can`t help any further on a forum like this, hv circuit needs to be looked at by a tech, gl, video-tek
Posted on Jul 01, 2009
Ecollier2012
  • 3459 Answers
SOURCE: I have a 53" Hitachi
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
Why does my sony 45 inch screen have mostly green color?
the color tv display used mixing of three colors, (red, green and blue). it lost one color, coomon problems: lose contact of base of picture tube or its wiring, sockets, capacitor dead in rgb section, dead video ic
Oct 05, 2014 | Sony KP-FX432M91 Projection TV 43 WEGA, 3D...
No problem, I just want to know if this tv has a digital tuner? It says it has a "digital comb filter". Is that the same thing?
A digital comb filter is not a tuner. It helps improve the appearance of digital content by splitting the luminance (brightness) and chrominance (color) of a digital video signal (DVD, or other set-top box). This filter is only needed when digital content is going to the TV over RF (coax) or composite (analog) inputs. http://electronics.howstuffworks.com/tv-buying-guide18.htm has some details on the filter,
Please provide the model number of the TV for additional information about the tuner. Normally the tuners will be listed as NTSC (analog), ATSC (digital), Clear QAM (unencrypted digital cable) in the US. In other countries you have PAL (analog) or DVB-T (standard definition digital terrestrial) or DVB-C (standard definition digital cable) signals.
I hope this helps.
Apr 15, 2011 | Televison & Video
I have a 32" flatscreen
Different video signals use different connections ...and we are speaking ONLY the video(NOT including the audio connections)
  • Composite Video (typically colored Yellow) uses 1 RCA connection on your TV
  • Svideo (uses 1 svideo connector on your TV) a circular connector with 4 pins in it
  • Component Video (typically colored Red/Green/Blue) uses 3 RCA connections on your TV
These are the common analog video signals....You cannot mix and match these and plug a composite (Sometimes called AV in menus) into component etc
If both your sources (wii/DVD) you want to use a component signal to your TV (which BTW is the best quality of the 3 I listed) you will need 2 component inputs on your TV
OR
run it through a high end receiver (that will act as your switcher)
OR
buy a small stand alone switcher, something like: http://www.amazon.com/4X1-HD-Component-Av-Selector/dp/B000BVIBGI/ref=pd_sim_sbs_e_4
settle for a lower quality DVD signal and use the Composite video out (yellow jack) into the Composite Video In on the TV and use the component for wii
I hope this helps,
Magoo
Mar 10, 2011 | LG 32LG30 32 in. LCD HDTV
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv went to black and white
It may be a wire has come loose. Check your video inputs. Especially if you have animals or small children. On certain video inputs you lose color if one wire comes loose.
Jul 20, 2009 | LG RU-44SZ63D Television
Is this tv model number HD-compatible?
that tv has 3-inputs digital comb filter
component video input
tv,vcr,and dvd
and also a S video input which can be connected to hp for video transfer.
yes it is compatible.
Apr 07, 2009 | JVC AV-36D303 36" TV
PURCHASED 52" LG LCD HAD A GREAT PICTURE.ALSO HAVE DIRECTV. TOUCHED THE MENU BOTTON SAW THE AUTO TUNING, THOUGHT THAT WOULD BE A GOOD FEATURE. WENT AHEAD AND LET IT RUN THROUGH ALL THE CHANELS. NOW IT...
Because you have DirecTV there is no need to use auto tuning. You simply changed inputs on the TV when you started auto tuning. Just use the input button on the remote to go back to the Direct TV receiver. Most likely it will be under Component (Color Stream) or HDMI input.
Dec 31, 2008 | LG RU-27LZ50C 27 in. HD-Ready LCD...
Mitsubishi TV; Model No. VS-45607
Straight from The Mits website
Intro Year:
2000 Chassis:
VZ8 Height:
48" Width:
38 3/8" Depth:
22 1/4" Features:
The Silver Series includes Mitsubishi's most cost-effective projection televisions, yet they outperform by wide margins many of the more expensive models of other manufacturers. With their superb picture, wide assortment of inputs and features, and highly capable system remote control, the Silver Series sets new standards for the entire industry. These exceptional performance features include the following: DIAMOND VISION Optical System 3D-Y/C Comb Filter: Delivers crisp color separations and smooth picture texture. Dynamic White Balance: Ensures color accuracy at all brightness levels. Three S-video Inputs: One in front and two on the rear panel, allowing quick and easy connection of a high-quality camcorder or video game, while simultaneously providing connections for home theater system components such as a digital satellite system and an S-VHS VCR. Component Video Input: Provides the best possible picture quality from a DVD player. 64-Point Digital Convergence Adjustment: Easy to use and provides precise color alignments. 2-Tuner Multi-PIP with Split Screen. 5-Layer Multibrand Remote Control: Allows the operation of a satellite or cable box, a VCR, a DVD player, and an AV receiver-all from one keypad. Intelligent Room Illumination Sensor (IRISþ): Automatically reduces brightness and contrast for a more pleasant viewing experience in a darkened room. Weight (approx.) - 178 lbs Power consumption - 240W
Feb 19, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Greenish tint
First of all component inputs are analog as the only digital inputs are the DVI or HDMI inputs on a TV. You might have color adjutments in the menus somewhere that allow you to compensate for color weakness on one or more colors. If not you most likely have a bad digital board.
Apr 07, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Electro Med Services...
