Question about Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau clicking My mother has a 15-year old Gaggenau gas cooktop, and spilled a glass of water on it this morning. Apparently it is now making a clicking noise (like the one when the burners are turned on prior to ignition) and won't stop, regardless of whether the burners are on or not. Does anyone know what is happening, and what to do to fix it? Thanks.
    President:
  • 878 Answers
Sounds like the spill got into one of the burner switches. This is not a big problem. Once it drys out it should return to normal. However if it keeps on clicking it could mean that one of the switches shorted out and will need to be replaced. The switches are located under the burner control knobs on the valve. Hope this helps. Catriver
Posted on Jul 28, 2006
My 5-burner 36" gaggenau has stopped working. I
Hello.
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Gene
Aug 08, 2011 | Gaggenau 36 in. KG 291 Dual (Electric &...
1992 glass top gas cooker ingitors keep clicking just out of the blue. We realize there is no gas being delivered until the knobs are on but we have to unplugg the cord from the wall to keep them from...
sounds like your spark module is being grounded out could be from something you spilled on the cooktop or it is just gone bad. if it is water it could take a week or so to dry out then problem will go away. have you spilled anything latley?
Sep 20, 2009 | Cooktops
I have a gas cooktop, probably 15 years old. it was operating normally until my wife spilled water across the control knobs. The next day 3 of the 4 knobs wouldn't turn at all. Then the next day they would...
the 15 yrs old unit is made from metal the gas line or the valve compare to the new is made from alluminium or bronce,i think the unit is have a rust b4 the water spilled accros the knob,u said after 3 days di not turn at all then after next day it turn it again,the posible coz is u force to turn it the valve that coz of damage it,gas valve is sensitive if u force to turn it coz is made of metal then the unit is almost 15 yrs old.for me dont try to repair it,coz the part is expensive or if there available in the market?compare to buy an new one.
tnx gerbee
phillipines
Sep 05, 2009 | Cooktops
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Mar 18, 2009 | Thermador SGS36GS Gas Cooktop
Jammed knob on Gaggenau cooktop
It looks like the gas valve for FR burner has to be replaced. Very unusual for Gaggenau gas cooktops.
Nov 18, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Kitchenaid Gas Cooktop with electronic ignition
you sound as if the short is occourring within the switch assy perhaps water has spilled on it, listed on gas range, but assuming you have an electric unit, with the knobs poking through the glass
Nov 09, 2008 | KitchenAid Cooktops
Gaggenau gas rings
The heat has caused it to be stiff. Just apply steady pressure and it will lift off. Gaggenau is real good about making sure that if a part is screwed down that you can find the screw.
Oct 23, 2007 | Gaggenau 23 in. KG 260 Gas Cooktop
Flame too low
Most probably dirty jets. If water was spuilled, there is a possibility of rust forming on some parts. Low flames are usually due to inadequate gas supply, due to dirty jets and burners. Often rust forms on the top burners in the little holes, causing slight blockage - clean the holes with a needle properly and check. Oshie
Jul 30, 2006 | Gaggenau 23 in. KG 260 Gas Cooktop
Gaggenau 23 in. KG 260 Gas Cooktop Logo
469 people viewed this question
Top Gaggenau Cooktops Experts
Paul Carew
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
