Question about Toshiba Satellite M55-S3512 Notebook
Usb i hook up the usb lime wire and it wont let me connect to xbox live what do i do
How can I update my xbox 360 system
To update on Xbox LIVE:
  1. Connect your Xbox 360 console to the internet. If your console is not connected already, see Connect to Xbox LIVE.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
  6. Select Yes if you are prompted to update console software.
Copy the Update to a USB Flash Drive If you don't have an Xbox LIVE account or have a slow Internet connection, using a USB flash drive is a good option.
Note: The USB flash drive must use the FAT32 file system.
Update using a USB flash drive:
  1. Connect your USB flash drive to a USB port on your computer.
  2. Click here to begin downloading the update folder. Save it as "$SystemUpdate9199.zip" anywhere on your computer.
  3. Unzip the File.
  4. Copy the contents from the unzipped folder onto the root of your flash drive.
  5. Safely remove the flash drive from your computer and plug it into a USB port on your Xbox 360 console. If your console is on, turn it off, then back on. The update program will start automatically.
  6. Select Yes when you are prompted to update the console software.
Dec 15, 2010 | Microsoft Xbox 360 Console
Tryin to hook up xbox live wireless but wont connect to internet
Xbox Live has been disabled for the original Xbox. Time to upgrade to a Xbox 360. Here's a link to the report: http://scitech.blogs.cnn.com/2010/04/14/original-xbox-live-is-no-more/
Apr 16, 2010 | Microsoft Xbox Console
Every time i go to campagin on halo 3 it wont load the mission upper right hand corner it say 1 player (16 max) then has my name i guess im in on lime mode or something idk please help
make sure your on the campagin part of it i got lost for some time thinking i was not being able to connect to live but i was in friends only insted of xbox live just make sure everything is correct before you try to log on one of the options on the left of the screen shoud have something saying xbox live
Jan 11, 2010 | Microsoft Halo 3 for Xbox 360
How do I connect Xbox 360 wirless network up
There are two ways to set up wireless connection to your Xbox 360, and get Xbox LIVE. Now remember, for you to do anything with the wireless connection, you need to buy Xbox LIVE. The company has a 3 month free trail for Xbox LIVE that you can sign up for. Then, when you have that bought, your true experience can begin. If you are fortunate enough that you console location is near your internet router, then you can hook up your 360's internet cord to the back of your router. then you will have to go to your internet configuration and test your connection, and you will have live. The other way is by going to Best Buy, Walmart, Target, Gamestop, or any other game seller and buy something that is called the Xbox 360 wireless connection router. I'm not sure if that is the exact name, but it looks like a pretty small internet router. Then, you hook that up to the front or back of your 360, into one of the many USB ports, and you install it. You may need help and may have to call Xbox 360 customer service. But, those are the two ways to get live.
Please rate.
Thankyou, Good Luck, Noob815
Dec 26, 2009 | Microsoft Xbox 360 Console
Connecting xbox 360 live
if you plug the computer into the usb port a box will come up and you register it as for the adapter get the one for the xbox plug it in and go to the dashboard then console setting then xbox live connection then test connection and if it doesnt work try the linksys one or the wired one.
Jul 12, 2009 | Microsoft Xbox 360 Console
Wont connect to xbox live
are you sure you have all the ethercables hooked up correcly? have you run out of xbox live? is your modem on standby?
Jan 20, 2009 | Microsoft Xbox 360 Console
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
XBOX LIVE
u may need to adjust your modem/router settings check this link out
http://www.jlsnet.co.uk/index.php?page=cc_xbox
Feb 15, 2008 | Microsoft Xbox 360 Console
Hey i just got a xbox live wirless hookup and i have a computer down staris and i dont no why it wont hook up can someone help me
It should hook up but Xbox live is having a ton of issues basically xboxlive is down and wont be back up for a while. you can go to www.xboxlive.com and search under status then go to support this will let you know when you can connect back up to xbox live.
If you problem isnt with xboxlive then you will need to get a wireless router. Then go through the steps to set up a wireless network and then set your xbox to that wireless network.
Dec 29, 2007 | Microsoft Xbox 360 Console
Toshiba Satellite M55-S3512 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
