Question about Maytag LAT2600A Top Load Washer
Washer will not fill for rinse cycle
My Maytag washer fills up OK for the washing cycle, but when it goes to the rinse cycle, the washer will not fill - the water goes out through the drain.
SOURCE: Help!! My maytag neptune MAH6700AWW is having trouble.
the fix was simple i just had to lift my drain hose off the floor. it had become disconnected from the back of the washer and was lying on the floor. I didn't realize that by it lying on the floor it didn't provide the proper back pressure to keep the water in while filling the tub. this was the NF error. as for the LE error. i haven't gotten it since i took off my cold water hose connection and ran hot water into it to losen the dirt/rust that was caked into the screen that is located in it. My washer is running like it is brand new again.
Posted on Feb 20, 2008
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here)
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
  • 20 Answers
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
is your drain hose at the top of the washer .is the water just runing out is it being pump out
Posted on Feb 20, 2009
  • 3361 Answers
SOURCE: maytag top loading washer won't agate.
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Posted on Feb 25, 2009
  • 1198 Answers
SOURCE: Maytag top loading washer fills up but won't stop
Check the fill control device and the tube that goes to it. Make sure there is not any debris in the outer tub where the tube connects. You may be able to push the drum aside to check.
Posted on May 04, 2009
SOURCE: maytag washer will not agitate during wash cycle
Above is a service manual this will show you how to troubleshoot and repair.
Posted on May 04, 2010
0 characters
1 Points
My maytag washer, will not fill w/waterit runs in
Check your drain hose. It only goes into the drain stand pipe from 4 to 6 inches. Insertion any further will creat a siphon and constantly drain the tub. The stand pipe needs to be at least 36 inches from the floor.
Dec 30, 2009 | Maytag HAV3460AWW Top Load Washer
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Maytag top loading washer fills up but won't stop filling on the rinse cycle. Doesn't do it every time. Sometimes it will start filling again after it agitates for a few minutes.
Apr 27, 2009 | Maytag PAV2300 Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag LAT2600A Top Load Washer Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Al Clark
Todd Marr
Todd Marr
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
