Question about Pioneer PRO-710HD 64" Rear Projection Television
Convergence IC's When watching a picture that does not fill the screen I have a balck line on the top and botton of the screen that about 2" wide but the middle of the black area pulls toward the center about 1" more than the outer edges. The grid square convergence adjustment works fine to aling the red and blue adjustments and the picture quality is great. when I watch something in 4:3 ratio, the entire picture pulls in to the center about 1" more than the outer edge of the box. I here that replacing the convergence amplifier IC's will fix most problems, But I am not sure if this is the case with mine. I was told my my dealor that if I replace the STK392-110 ICS's with STK-392-180 they will last longer. I would also like to know if they are a like for like replacement or will I have to replace some resistors also. Thanks for the help.
  • Jim Hoffman
    Jim Hoffman Jul 27, 2006
    I would like to add that when watching a program that fills the screen, I can not see any problem with the picture.
    Until a caption box or info is displayed on the bottom of the screen then I notice it.
    President:
  • 3,130 Answers
It does not sound like a convergence problem as you stated that all the lines match up and are ok??? You have space at the top and the bottom, as well as on both sides? Well my friend it sounds like you have a power regulator problem with the main power supply, because it sounds like the voltage is low and causeing the set to have a smaller then normal picture. Check the Main B+ first. I dont have a schematic but if you need, I know lots pof authorized pioneer peeps, and can getbwhat voltage and what part is most likly bad. We hardly repaired the boards as they(pioneer ) did not have most of the descrete parts and mostly had the boards themselfs to replace. You could also take out the B+ regulator board and have it rebuilt at PTS. They have a web addy of http://www.ptscorp.com Look them up and get their tele # and call them to see about the replacement cost. If they can't help go here Main support number800-421-1606. Good Luck
Posted on Jul 27, 2006
Make the picture fill the screen
The TV will produce a picture that is set by the aspect ratio of the film. You can however expand to an unatural size to fill the whole screen.
Oct 03, 2014 | Samsung Televison & Video
I have a samsung 42 picture lines top and bottom of screen
DAve1645 is correct!
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 28, 2009 | Samsung HCM4215W 42" Rear Projection...
Hitachi 50SBX78B Horizontal lines and bow
John, Hitachi site is down at the moment, if you remove the clips on the front of the IC`s you will see the numbers of the convergence ic`s, and yes they are a pain to get out, they are probably stk 392-110`s if they are the originals, you`ll have to un-solder 36 pins total to get them out, check for burnt resistors in the general area of the ic`s and replace any that are burnt before turning the set on,be sure to order a tube of "heat sink compound" to apply to the back of the new IC`s, once on the set will probably still look poor, this is normal, run the set for minimum of 15 minutes then push the " magic focus button " inside the front door panel, after it has finished running magic focus it should look great, video-tek
Feb 08, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
The tv you sold me
pin cushion is gone.
time to get a new one.
don't try to fix it. not worth the time of the money.
Sep 24, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Hitachi projection tv
I would change both ICs STK392-110 and also the 3.3ohm 1 watt resistors and the 1.8 ohm 1 watt you would need 2 of each resistor. Then your convergence would be new again. You can get replacement ICs and resistors at the following link with free shipping and free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jul 01, 2008 | Televison & Video
Sony wide screen projection tv model kp46wt510
Hi, replace the convergence IC`s and any discolored resistors in front of the IC`s, and you`ll be good as new, BMW Rider
Dec 30, 2007 | Televison & Video
Picture of rear projection tv
Convergence amp ic are bad.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
Oct 13, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Samsung HCN653W 65 in. lines.....lines.....help!
My first guess is it kind of sounds like a convergence board problem i know they had some service bulletins on them. hope that helps oh and convergence boards arent exactly cheap and will probably require some soldering
Mar 22, 2007 | Samsung HCN653W 65" Rear Projection...
Pioneer PRO-710HD 64" Rear Projection Television Logo
137 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
