Question about Fellowes 3011001 Shredder
"safe sense" won't turn off
The yellow SafeSense light comes on with both forward and back switching. Green power light comes on as well, but the motor doesn't move.
  • annek Nov 09, 2008
    I have the same problem, the safe sense light is always on. When I switch the switch underneath to turn it off it will run for a few seconds and then stop
2 Suggested Answers
  • 105 Answers
SOURCE: safe sense yellow light flashing, but shredder
the flashing indicates a past jam or safe sense turned off . you can reset the error by following the instructions in the owners manual. if you do not have manual go to www.fellowes.com , support and download the owners manual for your model.
Posted on Dec 04, 2009
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Feb 24, 2013 | Sharp Aquos Televison & Video
I have a 1993 Mercury Topaz that I just bought, and the drivers side seat will not move forward, it will go in all other directions, but won't move forward...any suggestions?
There are 3 electric motors on the seat. One is forward and back, one is front up and down, and one is rear up and down. The switch changes the polarity back and forth to achieve the proper movement. I think the wire color for the forward and back motor is yellow with a white tracer and red with a white tracer. so if the switch gives the motor positive voltage to the yellow with a white tracer and grounds the red with a white tracer the seat moves forward. If the switch gives the red with a white tracer positive and the yellow with a white tracer ground the seat moves back. (or the other way around). So we can safely say it is in the switch.
Good luck and God Bless
Jun 06, 2011 | 1993 Mercury Topaz
What purpose for the toggle switch under the deck??
Per the DS1 manual the toggle switch under the deck is the SafeSense override switch. The override switch deactivates the SafeSense feature so that you may clear a paper jam. When the switch is in the override (left) position, the SafeSense yellow light will flash and the SafeSense feature will not function. Once the paper is cleared, reset the SafeSense override switch to the right position.
Jan 28, 2011 | Fellowes DS-1 Shredder
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
Why is yellow light blinking on top of unit?
Per the DS1 manual the yellow light relates to the SafeSense feature. A toggle switch under the deck is the SafeSense override switch. The override switch deactivates the SafeSense feature so that you may clear a paper jam. When the switch is in the override (left) position, the SafeSense yellow light will flash and the SafeSense feature will not function. Once the paper is cleared, reset the SafeSense override switch to the right position. The SafeSense yellow light turns on when you touch or are too close to the paper insert opening.
Jan 18, 2011 | Fellowes DS-1 Shredder
Our lutron dimmer switch only has a yellow light and no green light. It obviously will not turn on any of the lights it is connected too. We have flipped all the breakers and everything is good. All the...
I would call their tech support center for clarification, because what you descirbe doesn't immediately make sense. The only light that a Diva has should be a yellow glow through the back of the plastic. If you're talking about a green light, then maybe you mean a Maestro, but there's no yellow light on a Maestro... it's making me think you may have a different manufacturer.
Regardless, call tech support to figure it out. They're at 1-800-523-9466 and available 24/7.
Dec 15, 2010 | Lutron Diva Dv-600P Light Control By
What are the stereo color codes for a 2002 jaguar x type 2.5.. hooking up amp with the factory deck and dont wanna buy the iso harness thaNKS
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red/grn & red/org |+ |ignition harness |
| STARTER|gry/blk or lt. blue |+ |ignition harness |
| IGNITION|green/black |+ |ignition harness |
| SECOND IGNITION|pink/white |+ |ignition harness |
| THIRD IGNITION|red/wht (key sense)|+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|pink/yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |DDM *1 |
| POWER UNLOCK|black/white *2 |- |DDM *1 |
| LOCK MOTOR|yellow/black | |DDM *1 |
| UNLOCK MOTOR|white/purple | |DDM *1 |
| DISARM DEFEAT|white/green | |pass. kick, harness to rear |
| PARKING LIGHTS +|use neg. wire only | | |
| PARKING LIGHTS -|white/green *3 | |headlight switch |
| HEADLIGHTS|white/green *3 |*3 |headlight switch |
| DOOR TRIGGER|black/white *4 |- |underdash light |
| DOME SUPERVISION|comes on w/unlock | | |
| TRUNK/HATCH PIN|white/black |- |REM *5 |
|TRNK/HTCH RELEASE|black/blue |- |release switch or REM *5 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| TACHOMETER|brown or brn/stripe | |main harness pass. firewall |
| SPEED SENSE| | | |
| BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch |
| HORN TRIGGER|gray/orange |- |FEM *5 |
| WIPERS|red/blk(L),red/grn(H|+ |wiper motor |
| LF WINDOW UP/DN|white - yellow |A |DDM *1 |
| RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 |
| LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 |
| RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the white/green wire. Using a negative trigger with a 780 ohm resistor in-line to the same white/green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery. hope that helps
Sep 27, 2009 | Car Audio & Video
Fellowes 3011001 Shredder Logo
91 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
