Question about ViewSonic N2000 20 in. LCD HDTV
Fuzzy Display Screen works, however the screen is a little fuzzy. What should be causing this effect?
  • Stoyanka Jan 07, 2008
    The screen is clear, but text is fuzzy.
    President:
  • 3,130 Answers
Check your sharpness control in the adjustment setup. If its set to max you might or sme sets have a tendancy to look grainy. Also check your source and be sure the signals strong. Such as just adding another tV to a cable line can cause weak signal. Ceck it with another set in its place. If thats the case simply add a small 20.00 cable amplifyer. Good Luck
Posted on Jul 27, 2006
Fuzzy Display
try to reset the device into factory defaults, you should be able to perform that from the menu. then set the native resolution and perform the auto adjustment.
Apr 27, 2008 | ViewSonic N2000 20 in. LCD HDTV
Fuzzy screen hp mini laptop
Try updating your graphics driver through Device Manager.
1. Right Click on "My Computer" on your desktop
2. Select "Properties"
3. Go to the "Hardware" Tab
4. Then select the "Device Manager" Button
5. Click on the tiny + next to display adapters
6. Right click on your display adapter and choose "update driver"
7. Follow the instructions and let it search for a better driver
If this doesn't work then you will need to bring it in to a computer shop to have the screen replaced. Get an estimate first before they do any work on it because it might not be cost effective to have it fixed. In which case you can hook it up to a monitor with a VGA cable to still use it, but it won't be portable anymore.
Good Luck!
May 14, 2012 | HP Mini 1010NR Notebook
May 14, 2012 | Computers & Internet
Ace 1 aspire computers works fine but the screen comes in fuzzy and unclear.
Bad connection from the motherboard to the screen, maybe a loose VGA cable
It could also be an overheated graphics chip, does the display appear to "shimmer" as well as being fuzzy?
Try cahnging the resolution and screen ratio, see if that helps first
Jan 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
Camera not working ,when in camera mode the screen is fuzzy and black
Hi Friend,
As you have mentioned that u are facing the screen fuzzy and black when u are in camera mode,i to was facing this same problem.Actually the problem is with the Display.
Once i have changed the display the problem has been got solved,So kindly change the display you will get a perfect solution
Regards,
Ayyasam
Jun 30, 2009 | Nokia 8800 Cellular Phone
Fuzzy Screen Display
this sounds to me that water has leaked into the screen
Apr 11, 2009 | Nintendo DS Lite
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
ViewSonic N2000 20 in. LCD HDTV Logo
154 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
