We had lost I/F module. We bought new one recently. We expect "ready" on disply of phone(soundstation2) connecting to I/F module. but "incoming call" displayed. We couldn't hang up. "incoming call" displayed even without telephone line connection.
Sir/madam,
Try to Restore default settings......
Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Restore Defaults
Restoringthe defaults will irretrievably remove all
settingsand data that have been entered since the
SoundStation2was first installed.
1. Press the Menu button
, choose Admin Setup and press
the Select button
, enter passcode (if required) and press
the ENTER
soft key. Choose Diagnostics using the Scrollingbuttons
, and press the Select button
2 Choose Restore Defaults using
the Scrolling buttons , and
. Press the
OK soft key if you wish
to restore defaults or the
CANCEL soft key or the Exit button
to return to the Diagnostics
submenu.
Phone Book entries and Speed
Dial numbers are not lost when
restoring all defaults.
Thanks
good luck
Try to change the battery .
You need to un-plug the phone remove the "mods" plug it back in and let it read not ready, turn the phone off. plug the "mods" back in ,turn the phone back on, so it can read them sequentially the should reset the system and let it "boot up" properly.
give that a shot...it should resolve this minor inconvenience.
If it has a battery in it, unplug the phone from the power socket and let it run dead. Then plug it back up and once it comes on, reset it (if possible) and let it charge up completely. It should work.
Try this: unplug all of the cords from the phone and take the battery out(if it has one) and let it sit for a while while it loses memory of what it has been doing. Put every cord in except the power cord and let it sit for 2 minutes. Then put the battery in if it has one, and plug back in the power cord. That should work.
TRY TO RESET THE PHONE
Try recycing the power on that...hook up the two modules with power off, then turn power on..it is possible that connecting them while on, would glitch the system
Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
Set the desired print quality, and you are ready to receive faxes.
I don't know how to reset phone(soundstation2). I tried restore default setting, but it didn't work.
I don't know reset procedure, there's nothing on the phone(soundstation2) to reset.
