Question about Nakamichi Soundspace 3 Shelf System
Nakamichi soundscape 3 main unit motorized lid
The motorized lid in the main unit does not open. this makes the entire unit useless. any suggestions??? thanks!!!
cheers,
~~~gary~~~
  • gary miller Nov 09, 2012
    anyone know how to fix the nakamichi soundscape 3 motorized lid.
Nightdiver
  • 116 Answers
SOURCE: Nakamichi Soundscape 5 3 Disc System
Hi David, Saving Presets: 1. Navigate to your favorite station with the UP/DOWN buttons. 2. Press MEMORY once. The preset choice will go to the next available one. 3. Within 5 seconds, press MEMORY again to save the current frequency as a preset, or else use the UP/DOWN buttons to fi nd another preset number, then press MEMORY to save it. 4. The UP/DOWN buttons usually tune the frequency, but when loading the presets, they navigate the presets. Try this and let us know if it works for you. Best regards, Bill
Posted on Jul 12, 2007
How do I open the cd drawer to remove a fallen paper clip
If you do a google search for "Nakamichi SoundSpace 9 service manual" you will see a PDF file that shows how to dismantle the unit so you can get the item out.
May 22, 2016 | Nakamichi SoundSpace 9 CD Shelf System
Jul 04, 2007 | Nakamichi SoundSpace 5 Shelf System
Nakamichi Soundspace 5 will not turn on with the remote or the power button
The main fuse, or power transformer is open, or the audio output ic has failed. Since you were having trouble with the remote and power button I recommend replacing the item, cost to repair will be high.
Apr 14, 2012 | Nakamichi SoundSpace 5 Shelf System
Hi I have a Soundspace 3 system and the CD always opens. I press Close and after a few seconds it opens again. What can I do to fix that? Thanks in advance Roger Fahlen
Often this is caused by something falling into device tip the device with the open tray so the tray points down and shake it gently if this does not fix the problem it is probably a mechanical fault with a gear or a censor
Mar 07, 2011 | Nakamichi Soundspace 3 Shelf System
Need cable connecting CD unit and Speakers soundspace5 (Mumbai)
If you don't find the cables I cna sell you the speakers with the cables!
Jul 26, 2010 | Nakamichi SoundSpace 5 Shelf System
Power supply unit for nakamichi soundspace 5
we are the distributer for Nakamichi in India. Please call +91 9871371720
Jun 29, 2009 | Nakamichi SoundSpace 5 Shelf System
Soundspace3 power supply
This will fix your problem, visit Power Supply Guy on Ebay, Item # 200365155512 or copy & paste this link:http://cgi.ebay.com/Nakamichi-Soundspace-3-Stereo-System-Power-Supply_W0QQitemZ200365155512QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2ea6b1a4b8&_trksid=p3286.m20.l1116
May 31, 2009 | Nakamichi Soundspace 3 Shelf System
Changing time from military to standard
According to the manual, you have to flip the switch on the back of the main unit, unplug and replug it into the outlet.
Apr 24, 2007 | Nakamichi Soundspace 3 Shelf System
Ejects CD'd rather than playing them
You probably have problem with central sensor on CD mehanism,it may be dirty,its doesn't give information when changing discs and unit "things" that you press OPEN.It can be very tricky do fix because you have to dissembly whole CD mehanizam and if you are not good in it its better to find a good service
May 03, 2007 | Nakamichi SoundSpace 5 Shelf System
Nakamichi Soundspace 3 Shelf System Logo
114 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
