I have to hold down a key for 3 sec before it shows up
    New Friend:
  • 27 Answers
What is showing up ...?>more details please
Posted on Oct 22, 2008
How do i reprogram my key on peugeot 307 hdi 2001
Many cars have a different process to enabling passive systems, some require turn the key on and off 3 times then hold it in the on position while holding down the remote, or you may hear a chirp to start the calibration process, the safest way of course to marry the unit to the vehicle is to scoot down to the Peugeot dealer and get them to do the program, it may cost, but they also have to make sure everything works correctly too, so they will stand by the service they provide you. hope this helps, happy holidays.
Nov 29, 2014 | 2001 Peugeot 307
The "key" shows on the screen
Hola! You have activated the Child safety lock! Yes Mam! Usually to unlock it you hold down two buttons X 5 secs. You OWNERS MANUAL will tell you about this feature! Good wruck!
Jan 16, 2014 | Siemens Washing Machines
Volkswagon,Jetta,1998I need to know how to reset anti theft device. I do not have fuse\relay diagram.
unlock car with key/hold key over for 30 secs...lock car with key/hold over for 30 secs,then press remote button to unlock and hold down for 30 have just reset the system.AND if your car has the comfort mode the windows will go down then up when you hold the key over so you reset the window rollback as well.
Aug 20, 2010 | 1998 Volkswagen Jetta
Lost code for 1996 toyota prado radio l had the battery replaced now the radio displays a sec sign
for our Toyota Prado 2001 01, after the battery had been removed SEC was showing on the cd / tape / radio display. To remove the security SEC warning, find the last 3 digits of your VIN number (under the hood) hold down the "TUNE" button and then press "1"
Then use the numbers 1 2 and 3 to type in the last 3 digits of your VIN number.
Quickly hold down "SCAN" button, the radio will power off, then press the volume button to turn it back on.
-I accidentally held down "auto" before holding down scan, I don't think auto has any part of fixing this (just an error on my part) but if the above doesn't work, you could try hold AUTO down after entering the digits then hold scan - just as I did.
SEC has now been removed, enjoy your radio!
Feb 08, 2010 | Car Audio & Video
With dell keyboard. When I push a key it will not
Had the same problem. Get a pointy knife & run it up & down between the keys. You will be amazed at the RUBBISH that comes out. Then hold it upside down, & with a stiff bristled brush, clean out the rest of the RUBBISH over a sheet of newspaper.
Jan 29, 2010 | Dell 0Y3740 Keyboard
Keep copier ready; disable powersave option
This is going to be a user program:
1) press and hold both light and dark keys
a) the 2 buttons to lighten and darken copies
b) hold both for 5 sec until indicators light up
2) use the left copy quantity key show 2
3) press your copy key
4) use the right quantity key to change to 2 (max 90 sec)
5) press the copy key
repeat step 2 but change to 3 with left quantity key
press the copy key
change right number to (4 = 60 min, 1 is default at 5 min) then press your copy key.
Once done press both light and dark key again to exit
Note*** changing shut off timer and preheat will effect copy lamp ready state. Every 60 sec or so the scanner will move and reset. Some people do not like the noise is makes all the time. If you don't you can always change it back to the defaults. 2=0 and 3=1.
Oct 12, 2009 | Sharp AL 1631 Copier
Ricoh Aficio showing error code SC555
Press the total reset(yellow) key - 1 -0 - 7 and press and hold down he stop ((red) key for more 3 sec.Enter in the SP mode(activate to press on the touch pane) open the front door turn OFF the power main switch,unplugged the machine amd wait 10 sec.Plugged the machine,closed the front door and turn ON the power switch.The copier is worked.If neccessary to check and measurement the continuity of the fusing unit parts:heater lamps,thermofuses,thermoswitch and if cleaning used the izopropilalkohol.
Sep 30, 2009 | Ricoh Aficio MP1600SPF Copier
I am getting an error message "S545"
Fuser unit malfunction code.Check the connectors,thermistors and thermofuses.Reset the code :enter in the service mode (press total clear yellow key and pres 1-0-7 press and hold down more 3 sec.the Clear key (red C key)) turn OFF the machine,umplugged the cords wait 10 sec,plugg the cords amd turn ON the copier.
Aug 14, 2009 | Ricoh Aficio 1035 Copier
Refilling of canon ink fine cartridge pg 41
Phew! Finally. This one works for my Canon MP140.
Follow all instructions completely or it won't work....
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Apr 26, 2008 | Office Equipment & Supplies
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
