Question about Stanley Measuring Tools & Sensors
How to level my level for 360 degree range
When i get centered within my bubble and turn the head 180 degree or better it does not stay with in the bubble lines.
    Problem Solver:
  • 18 Answers
The level is meant for 360* of USE not from one single position check both horizontal and vertical... I think that one is a Moveable
Laser? Level?
OH I just found .. is it on a tripod like attachment? there should be a small round "level" on the physical Base of the level itself .... (like the ones your drill would have for drilling down into the floor boards) You must level it that way First.... then you can use it ...
Posted on Oct 26, 2008
How do I fix a thermostat that sticks and temp goes to 250 degrees on a 1999 Grand Am. I put a new thermostat in
New thermostats do not stick. With the radiator full and the cap off check for air bubbles at idle. blown head gaskets blow bubbles
Sep 10, 2014 | 1999 Pontiac Grand Am GT
Center bubbles will not level to center when it was turn to 180 degrees
Fix the instrument to a solid tripod. Level the vial. Turn the instrument 180 degrees. If it is out of level. Adjust half of the bubble's error with the foot screws, and the other half with the 3 adjustment screws around the vial itself. Continue to go back and forth 180 degrees until the two sides match.
It will take some time to get the hang of. But is not hard to accomplish.
Jan 02, 2014 | Topcon At-g2 Auto Level
How do you calibrate and Abney Hand Level? The one I have is a CST/Berger 17-645.
You need a carpenters level longer than the Abney level. Find a smooth flat level surface like a table with the carpenters level. Double check the carpenters level by turning it 180 degrees and see if it still shows level. If it doesn't get another carpenters level. Set the Abney level at zero and lay it on the carpenters level or the flat table. The bubble should center on the index line. There is usually two screws that allow you to move the glass tube (and the index at the same time) to center the bubble and index if it is off. Then check your findings. Put a piece of contrasting tape on a wall at eye level. Walk back 20 or 30 feet and see what the angle reading on the Abney level shows. If you keep your feet in the same position; that is your eye at the same level, you should read zero.
Oct 28, 2013 | Sokkia Abney Level with Clinometer 804710
I have a lufkin 20x level that is so far out of calibration I can't seem to get it adjusted properl;ey. What is the start from scratch procedure?
I assume you are talking about a bubble level. If so, you should be able to remove the cover over the bubble and find adjusting screws used to calibrate the level. Make sure the bottom surface is free of nicks and rust and is not twisted or bowed. To test for bow, after you have removed any nicks or rust, set the level on a smooth flat surface. Try to " spin " the level gently from one end. If it rotates about the center of the level it is bowed with the center high. If the center is high enough to rock the level you will never get it adjusted until you correct that condition. If it rotates about the end of the level it is bowed with the center low. If your surface is reasonably flat you can rub the level and look for shiney spots on the bottom. If it worn badly have the bottom resurfaced. If it is reasonably flat on the bottom, find a smooth, flat surface that you think is reasonable level. Set the level on the surface and mark its position. Take note of the bubble position, even if it all the way to one side. Reverse the level position 180 degrees and note the position of the bubble again. Make an adjustment to move the bubble half of the difference between the two readings and repeat the notations of the bubble and reverse position bubble. Continue until you obtain the same bubble reading in each position. If you don't get a final reading that is on the scale of the level, find a surface that is more level and try again. As long as the surface is level within the range of the level scale you should be able to adjust it until you get the same reading in each position. (If the surface is not level within the range of the level scale you can't complete the calabration.) The final reading should then be the amount the surface is out of level.
Apr 23, 2011 | Garden
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
On My CST berger 32X automatic level unable to hold vial bubble center as instrument is rotated 180 degrees - instructions say to use vial adjustment screws to correct this problem...this does not seem to...
take a topedo level and get the tripod base as level as possible. attach your level to the tripod. put all screws in the middle and level it. turn 180 degrees, level it. turn 180 and check. if withing the bubble, turn 90 degrees and level. turn 180 and so on and so forth. the adjustments should be slight from turn to turn. make sure the feet are secured firmly in the ground. If this does not level the automatic level, it needs sent in for calibration. I dont know the web address but I hope this helps
Dec 21, 2009 | RTO CST/Berger 55 - SLVP32N 32X SAL...
Head gasket what does it mean when you torque 90 degrees
IF you put a rachet on a bolt and handle is at 12 oclock you would turn from 12 to3 oclock.a circle is 360 degrees, half a circle is 180 degrees 1/4 is 90 degrees, hope this helps good luck.
Oct 30, 2009 | 2001 Daewoo Nubira
How to adjust a David White transit level
I just assisted a friend "re-calibrate" his D.W. L6-20 Level Transit. Follow the following steps.
1. Set up the tripod & transit in the garage. Get the platform with the protractor, close to level.
2. Position the telescope at "0". The telescope should be over 2 of the adjusting screws.
3. Adjust the screws to get the top bubble close to level. Adjust with a screwdriver the spring loaded screw to get the bubble closer to center.
4. Rotate the scope 180 degrees. Note the difference in the bubble position. Split the difference from the first bubble location by adjusting the same top screw.
5. Rotate back to 0. Adjust the same top screw to split the difference in bubble position.
6. Rotate back to 180 degrees. The bubble should be off by the same amount. Adjust the 2 bottom screw to place the level in the center.
7. Rotate back to 0. The bubble should not move.
8. Rotate to 90 degrees and adjust the 2 bottom screws to place the bubble in the center.
9. Rotate to 270 degrees. The bubble should be centered.
10. From this point on, all you need to do is place the level on the tripod and position it over your reference point with a plumb bob. Adjust the bottom 2 screws at 0 and again at 90. The level is set to use.
Sep 05, 2009 | David White 44 8834 1 22x Level Transit...
Cly head torque settings
The torque is 44 ft lbs+ 95 degrees. You will have to replace all the head bolts/ one time use only. Working from the center out tighten all to 44 ft lbs. Then from center out again go anothre 95 degrees. Good Luck
May 17, 2009 | 1999 Chevrolet Venture
Nikon az1 auto level
There are 2 allen screws on the fish eye bubble that can be adjusted to correct that problem.
First level the instrument;
Then turn 180 degrees
Adjust the vial until the bubble is half way from where it is back towards the inner circle.
Relevel the level using the foot screws
Then turn 180 degrees again (back to where you started)
It should be mostly fixed, however if it is not just repeat the steps above; it gets exponentially better everytime until you can no longer detect the error.
Aug 02, 2008 | Nikon Optics
Measuring Tools & Sensors Logo
203 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
