Question about Kitchen Ranges
St croix pellet stove
Versa grate cleaning system should I be able to see the shaker grate move while the pellets are burning?
Had the same problem which I discovered this weekend..........
I have an eleven year old Afton Bay....the versa grate was not moving. I look into the inner workings of the stove and saw a bracket which had broken off....
The bracket was attached to the versa grate rod and made contact with the cam system in the stove...this is what moves the versa grate...........
I called my dealer, the part costs about $12.00 and looks like it can be replaced with out having a service guy come out..........
Hope this helps
Posted on Nov 09, 2008
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' Hearth.com ...
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
What is causing the ready light to flash red twice when I try to light my pellet stove
[PDF]INSTALLATION AND OPERATION MANUAL - Wood Pellet...
woodpelletheat.com/WinslowManual.pdf
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
My stove keeps going out on E2 and shuts down why
The E-2 Error code indicates an automatic shutdown because the stove does not detect a fire. Check out Englander's troubleshooting guide to some of the causes.
http://www.heatredefined.com/faq/troubleshooting-guide/pellet-stove/evolution-pellet-stove/evolution-pellet-troubleshooting-guide/e-codes/e-2-failure-to-start
Feb 27, 2015 | Englander Direct Vent: 2,000 sq.ft. Pellet...
My st croix Hastings pellet stove is 3 yrs old and is not blowing as much heat as it has in the past. What could be the problem?
Hi, Check to see if vents are free of debree (spider webs etc...) Clean fan if necessary. Also try a different pellet some pellets will burn hotter. Good Luck.
Feb 04, 2015 | Heating & Cooling
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
Feb 20, 2013 | Northern Tool and Equipment Pellet Stove -...
I have a 1991 J1000 Jamestown pellet heater. I have read the start up manuel but it keeps dropping the pellets and they just keep piling up n running over the sides. Then I have flame all over the box
my jamestown was doing the same thing. a thorough cleaning of the pellet stove solved this. Look in the manual under Cleaning and maintenance.
Nov 05, 2012 | Pool & Spa
I purchases an elcipse pellet stove in 1990. It still works perfectly. I need to replace the insulation blocks for the side walls and also need a new ash pan. Do you know where i can purchase these items.
Elcipse was manufactured by Warnock Hersey, but was sold to St Croix. So, their parts may be interchangeable with your stove. Try Pellet Stove Parts.com and click on other brands for St Croix.
http://www.pelletstoveparts.com/mm5/merchant.mvc?
Feb 22, 2011 | Heating & Cooling
St.croix pellet stove
your either burnig the wrong type of fuel, or the fuel you are burning is wet, not burning hot enough resulting in cloudy door
Feb 03, 2009 | Kitchen Ranges
Kitchen Ranges Logo
295 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
