Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Linksys WUSB54GSC Wireless
Wireless adapter will connect to router for a while, then connection quits. Sometimes in 10 min. , sometimes in 4 hours. No matter what I do, I can not get connection back. Lights on router stay lit (linksys router wrt54GS), but no lights on USB adapter. Drivers are installed, Hardware profile says all USB ports on computer are working properly. I returned adapter and replaced with new one, but same problem keeps happening. All new equip. Linksys tech support (Hapu in India) not much help - they have me check MAC address and channels, but everthing is always correct. If I turn system off for a while, upon restart wireless will hook back up - untill it quits again. Any ideas ? I have not replaced router yet - I can hook up the ehternet cable instead of wireless and everything is OK.
  • 3 more comments
  • jesusbell_li Jan 03, 2009
    I have exactly the same problem. Damn irritating. Connection from my laptop is fine so figured something must be wrong with the adapter. Have used it for some time, it was fine all along till recently. So you think it's the same problem? Have not managed to try the proposed solution - having trouble getting a connection!
  • Anonymous Feb 04, 2009
    I have the exact same problem with ver 2 of the wusb54gsc. I can reconnect fairly quick <1 minute by unplugging adapter, wait app 10 ~ 15 seconds and then about 15 more seconds to connect to the internet. Can't find anything on this ver 2. Bought at Wal Mart, and linksys support doesn't have anything on the ver 2. Am using Vista 64 on Dell Studio XPS 435 MT.
  • jbrigden Feb 09, 2009
    Same problem as above except now it will not even find my encrypted network. Encryption has not changed.
    Problem started with just not staying connected to my network...kept jumping to neighbor's weaker network. Progressed to where it would see my network but not connect, now it will not even see my network. 2 other computers regularly using wireless and no problems...one is belkin adapter and other is unknown (came with the laptop).
  • grantnunn Feb 18, 2009
    Have the same problem, zoom router + Linkysys adaptor, connects fine first time then 1 minute or hours later will lose the internet and the adaptor light will stop flashing but im still connected to the router. I have another computer on the network so i know the router is fine. I tried the services suggestion but wireless zero config is'nt started to stop. Ive noticed that i get a number after my conection to such as "Wireless network connection 8 (zoom)" Any ideas???
  • Anonymous Feb 21, 2009
    I have the exact same problem. I have uninstalled and reinstalled. Nothing works.
Right ive fixed this but im not sure how cause i have done about twenty things....the adaptor is in a different port, as in it was plugged in at the front of the PC but now is in the rear, i have turned off my firewall, i also went in to the registry and removed the old connections that had been created, these can be found here HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services. Thats all i can think of for now that is relevant, one other thing if like me you found yourself unpluging and pluging in the adaptor every 2 minutes into differnet ports this only works if you restart the computer each time, just thought id point this out. Hope this helps some of you but mine has been on now for 3 days now without dropping off once so i must have done something right just as i was about to buy a new adaptor.
P.S. If you solve your issue using any of these methods or a new one please let everyone know, Thanks
Grant
Posted on Feb 21, 2009
    Master:
  • 409 Answers
On your PC goto Start/Control panel/Administrative tools/services
When you have a good connection stop the "Wireless Zero Configuration"
This should stop your issue.
Posted on Oct 21, 2008
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Nov 01, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Will not recognize linksys network
i suggest that you install the drivers and then connect the usb card when you see the wireless connection on the tray close to the clock, click on connection manager and click on the wireless connection that belong to you . there is two ways to manage your connection one with the software for the wireless card and also you can let windows manage the connection hope this help you
Jul 28, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless adapter will connect to router for a while, then connection quits. Sometimes it stays on for a while - other times not for very long. Lights on the modem stay on but connection does not return -...
Hi there, sounds like you need to sync your modem and router. First turn off the power to the modem, then to the router. After a few minutes reinstall the power to the Modem then to the Router. Restart your computer and see if you now can connect. Good Luck...
Oct 22, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
How to setup the Linksys Wireless-G Broudband Rauter
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 06, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless-g usb adapter fails to connect to router
if your wireless router has security enabled, as a first troubleshooting step you can try disabling the security. then see if the USB adapter can connect. IF it still cannot conenct check for the default channel on the router and on the adapter side.
Jun 03, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
How to start over with a secure connection with a wireless
1)Press the reset button on the back of the router.
2)Open your browser and type in 192.168.1.1
3)Then login as administrator and set your configs.
May 24, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Failed connection - Linksys Compact Wirless-G WUSB54GSC adapter
1.uninstall the driver
2.restart computer..
3.in the windows..run the cd driver of WUSB54GSC and install...next..next...after that..restart computer...
4.in the windows..insert your linksys usb wireless device...and start using your wireless..
Jan 04, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
504 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
