Question about Midland 77-115 CB Radio
Bracket knobs Anyone know what size bracket knobs are used on this radio? Are they 4, 5, or 6MM?
  • ptcruiser1 Nov 01, 2008
    Thank you, yes they are the 6MM. Found that out by purchasing 4MM, 5MM and 6MM. The 6MM fit.
    Thanks again
  • 204 Answers
Hello ptcruiser 1, I don't have one of those radios right here in front of me, but if I remember correctly the knobs are 6mm. I'm trying to remember for sure but I know their not 5mm, that's the size of most Cobra's. It's been over a year since I've had my store open, so I'm working from memory. That's the best I've got,,, Mechanic
Posted on Nov 01, 2008
I am trying to get the front panel of my radio off so i can replace my antenna how do i get the front panel off
That depends on what kind of radio it is. If it has a knob on either side, pull the knobs straight off and you should see a 6-sided nut on a threaded piece, one on each side. You use a socket or needle-nosed pliers and remove these nuts and your radio should come out backwards. I've often pulled the antenna lead right there and put the new on one. You should know it just goes on the back of the radio. If it isn't one with knobs, you'll have to remove screws from the brackets that hold the radio in place. Just look at it and you should see. If this confuses you, get someone who knows that to do, to do it for you...just to be safe. Good luck.
Nov 28, 2013 | 1994 Oldsmobile Cutlass Supreme
Alternator diagram for 2002 Isuzu Rodeo
Does anyone know the sizes of the bolts that bolt the alternator to the lower bracket and the lower bracket to the block? Someone has put a slip style lower bracket on my trooper as if I would have to adjust the belt tension manually and I am not too keen about that. I have bought a lower bracket but it did not come with the bolts.
Dec 04, 2012 | 2002 Isuzu Rodeo
Bottom bracket need replaced. needs a new crank set. what size if the bottom bracket and what size crank set is recommended, or does the bottom bracket need to come out to find the size. bought the...
impossible to tell you without knowing the bike brand and model and year, although you have provided that 1999.
If you take into a bike shop, which is the usual place to purchase the parts you need, they will be able to tell you what size Bottom Bracket will fit your bike, also what options you will have for replacement cranks and bottom bracket. This could be a very complicated issue when replacing with parts that are 11-12 years newer, the shop will be best equipped to give you all your options.
Apr 07, 2011 | Cycling
I am trying to install a radio in a 1965 Nova and can't find anything on how to do this. Is there a schematic somewhere for this?
First of all, in 1965 there was a one size fits all AM radio that was installed in the Nova. I was a teenager then. Hardly anyone even knew of or had heard of FM radios for cars. Just Cadillac, Lincoln and Chrysler Imperial folk. And of course Rolls Royce. But that doesn't count.
Here is what went into radios of that vintage. The Dashboards were metal so the radio ground was the dashboard. The hot was (I think) red. It may or may not have had a fuse in it. Probably not.
The speaker, usually only one was also grounded to the chassis and a single wire came out of the radio for it. You might have had a rear speaker, again with a single conductor going to it.
To unbolt the radio from the dash you took pulled off the metal knobs.(Plastic ones were a dim thought in someone's future imagination). then you removed the nuts around the two knobs shafts. The right knob was tuning and the left knob was a concentric control with a volume control in the center and a tone (only treble) control on the outer know. To remove you simply pushed the thing out and usually it fell out on the floor. If you are going to put in a High End sound system (relative to the period, everything now is super high end) I would do the following. I would at least use the line to the cigarette lighter to power it. I would definitely use a fuse in the line, because the lighter on that car stayed on at all times. whether or not the ignition was on or off.
You can get templates and radios today that do fit nicely into the old cars.
Hope this helps,
Happy Listening,
Best Regards,
Jan 04, 2011 | Chevrolet Nova Cars & Trucks
Trying to remove factory radio from 86 chevy g20 van with shaft style openings were to begin
remove the doghouse . remove the knobs and shaftnuts behind the knobs. to the right of the dash there will be a metal bracket attached to the radio and the body of the van. remove the bolt and disconnect the wiring and remove radio from behind dash
Feb 08, 2010 | Kenwood Car Audio & Video
Brake caliper removal
Sometimes they use a T-50 torx bit, and sometimes they use either a 15mm or 18mm bolt, however the caliper bracket is a 21mm bolt
Oct 06, 2008 | 1999 Chevrolet Silverado 1500
My icemaker makes large hunk of ice
Jun 17, 2008 | Whirlpool Gold Series GI15NDXT 15"...
Radio Communications Logo
48 people viewed this question
Top Midland Radio Communications Experts
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
