Question about LG DLG5932W Gas Dryer
DLG5988B Won't Heat
I don't know where to begin? I don't know how to locate the igniter and the thermostat, can someone please tell me where and how to get to it without damaging the dryer? lol
  • jrfrnilan Oct 29, 2008
    We have had the repairman here three times since purchase in June 2005. He has contacted LG customer service with no return calls. I have written a letter with no response. He told us that there is a reset button under the drum somewhere that resets the dryer to heat. Just today the same thing happened again and we have a call into the repairman to see if he will tell us exactly where the reset button is. Don't know if that is helpful to you or not.
3 Suggested Answers
  • 943 Answers
SOURCE: Dryer not Heating up
hi thanks for the question i would also check the thermal fuse when you purchase the hi limit thermostat also purchase the fuse a lot of dirt in venting will cause the thermal fuse to fail the appliance doc
Posted on Sep 27, 2008
  • 489 Answers
SOURCE: I have a LG dryer (DLG5988B) with no heat, maybe
First check the high limit switch to make sure it didn't trip. You will need a multi meter to check.
Posted on Jun 18, 2011
Gas dryer lg trom dlg5988B does not get hot.
If it has been under water you need to have it professionally serviced. The gas igniter is electronic and there are safety circuits to prevent explosions and getting gassed..
Nov 26, 2017 | LG Dryers
New battries in Duracraft Programmable Thermostat for A/C...still won
Remove the thermostat and just touch the wires together and make it run until heat wave is over then figure it out. Kinda of a pain but at least it be cool
Aug 07, 2017 | Honeywell Electronic Programmable...
Won't heat the water
Continuity check from the input to the output. If open, then check from the heater element to the out put and then the other side, then the switches and other safety switches. When you find an open component that shouldn't be you have found your problem. You need and ohmmeter or continutiy checker. If don't know what I am talking about get it looked at by someone who does. If you do, then I should have to tell you any of this.
Nov 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Viking oven gets warm but not real hot. The coil does not get red and appears to be not working
Typically the problem is with the oven controller. IF your RTD (resistive temperature device) is ok then your oven controller board is faulty. When the oven is turned on (bake mode) the oven controller closes the relay that controls the bottom element and the oven begins to heat. The RTD or thermostat provides a feedback loop to the oven controller. RTDs don't partially fail, they either work or they don't. Since your oven is getting warm I would imagine the RTD is okay. You can verify the RTD by measuring its resistance at room temperature. Remove power from the oven and either remove the RTD completely and measure with an OHM meter or remove leads and measure while still attached to the oven chassis. You may have to remove it if your ohm meter leads won't reach. I don't know your model oven but most RTDs at room temp are about 1.1 kohms or 1100 ohms. If this is the case your RTD is fine and your controller board is bad. Please let me know if you need anything else. Good luck!
Jul 02, 2011 | Viking Kitchen Ranges
I have a LG dryer (DLG5988B) with no heat, maybe the igniter is bad. What is the part needed, and can I replace the igniter myself.
Jun 17, 2011 | LG Dryers
My 1999 masda 626 won't start. it turns over but acts like it isn't getting any fuel.
check relays/fuses first then the pump if you know how to test it
the pump is easy to test locate any fuel line unplug it tell a friend to make a quick one key turn if squirts fuel then pump is fine
but check the pump relay first to make sure and to begin with simplest
it seems you can tell it is the pump but you don`t know where to start
Jun 07, 2011 | 1999 Mazda 626
Dryer is always "Cooling", doesn't heat. Why? How ...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 20, 2010 | LG DLE2514 Electric Dryer
Will not heat up in any cycle
If this is an ELECTRIC dryer, the following link will give you some advice on how to troubleshoot a no heat problem:
If this is a GAS dryer, the most common failure for heat related problems in a gas dryer is a weak or blown igniter on the burner assembly. The way the ignition system is supposed to work is like this:
1. Select the dryer cycle and press start.
2. The drum begins to spin and the igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
  1. NOTE: It can take roughly 30 – 90 seconds from the time you start the dryer to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the appliance that prevents free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the dryer still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
You can purchase a replacement at any of the following websites:
The first three sites on the list also offer some excellent exploded view diagrams of the appliance.
If your replacement igniter comes with a connector plug that does not match your appliance, you will be instructed to cut the old plug off and splice the wires together using ceramic wire lugs included in the kit. Do not use standard wire lugs as they will melt.
If you have any questions, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope this helps you.
Dec 21, 2009 | Washing Machines
Sep 27, 2008 | LG DLG5932W Gas Dryer
LG DLG5932W Gas Dryer Logo
73 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
