Question about Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster
Egg Poucher no longer works
The springy wire broke that gets hot. Is there replacement parts???
  • Anonymous Oct 26, 2008
    The egg Poucher does not work
  • waternomad Mar 17, 2009
    The steam tray doesn't work. Doesn't make any noise nor does it expel any heat. The "egg" button does turn red though.
  • 8,596 Answers
Here is the replacement parts link:
http://www.focuselectrics.com/finditem.cfm?itemid=3733
-Tha Mp3 Doctor
Posted on Mar 25, 2009
I am missing the measuring beaker (part CEC-7BK) that is used with the Cuisinart Egg Cooker. They are no longer available in Canada and several US companies don't ship here. Any solutions welcomed.
Hard: 1 egg/8 TB; 3 eggs/7 TB; 5 eggs/6 3/4 TB; 7 eggs/6 1/2 TB. Medium: 1 egg/4TB; 3 eggs/3 3/4 TB; 5 eggs/2 3/4 TB; 7 eggs/2 1/2 TB. Soft: 1 egg/2 1/2 TB; 3 eggs/2 TB; 5 eggs/1 3/4 TB; 7 eggs/1 1/2 TB. Note:oddly, the amount of water goes down instead of up for more eggs.
Dec 02, 2011 | Cuisinart CEC-7BK Egg Cooker Beaker with...
Tip
Car Over Heating!! Simple Temporary FIX to get you home.
We ,, well most of us have had our cars over heat at times, and sometimes in places that we wish id didnt happen. I will detail a few tricks here to get you on your way or back home safely.
Why do cars over heat?
Simply because it gets too hot!!, There are several reasons for this ,
1.) radiator has no water
2.) radiator is leaking
3.) Thermostat isnt working
4.) Fan isnt working
If your radiator has no water then u have to shut the car off. Use cool water and pour over the radiator cover until it gets cool to your touch (NEVER OPEN A HOT RADIATOR, PRESSURE BUILDS WITH THE HOT WATER AND IT WILL EXPLODE OUT AND BURN YOU). when its cold enough for you to touch, use a damp cloth to open the radiator cap, keeping your face clear of it, Start your engine, and add water to the radiator. (Dont Add Water To a hot engine without starting it)
If your radiator is leaking then allow it to cool a bit and follow the above instructions to get it opened. Crack an egg (whole egg without shell) in the radiator before adding water. (keep engine running) the egg solidifies in the hole and plugs it enough to get you home. If you plan to repair the radiator, u must flush it out first to get rid of the egg and other contents before welding.
The thermostat!!
If this isnt working propperly the fan wont turn on, follow the instructions for the fan below.
Fan aint working
Look closely at the fan you will find you will see a tube of 2 / 3 wires connecting to its motor. it connects there via a clip. unclip it. there will be 2 wires sometimes 3 . One of them is a positive (blue,brown,red) and the other is a ground (black or black stripe) cut them , use extra wires and connect them to the positive and negative of your battery terminals. The ground can also be placed on the body of the vehicle.Remember to disconnect these wires when you get home or it will drain your battery.
There you have it. A few simple to help get you home safely in the event your vehicle overheats.
on Feb 24, 2010 | Toyota Land Cruiser Cars & Trucks
Car runs ok, but gets hot and rotten egg smell comes out of the exhaust
If car runs okay with egg smell, its normal and working the way it should, if car is running poorly and the rotten egg smell has gotten worse, its a sign that your exhaust catalytic converter will need to be replaced. good luck!
Aug 12, 2011 | 2001 Oldsmobile Alero
I was given this toaster as a gift from my daughter. It failed after being used 4 times. Being a retired electronics engineer, I took the unit apart and found that a small relay that operated the toaster...
Unfortunately this is the sadddest part of our enviourment problem but the best part for the economic boom. Unless the unit is discarded the companies cannot surrvive.Hence most of the models are scrapped for no reason to make way so that the product sale continues.
If by cleaning the relay the fault can be rectified , try to do it with a good contact point/switch cleaner.
If the relay coils are damaged, the use an external relay if a similar type is not available.
the last option is to source one from a damaged set, sets discarded for coil failure etc..Try to salvage this part from old service shops,junk yards or second hand dealers.
Hope you find my tip helpful.
Aug 22, 2010 | Back to Basics TEM-500 Egg & Muffin...
No longer cooks eggs
check the wire (when is disconected from the main electric suply), check the heating element's and the thermostat's. or buy another, is more ceaper if you don't have waranty.
Feb 20, 2010 | Crock Pots & Slow Cookers
Back to Basics TEM-500 toaster no longer heats up
We have the same problem after only about 20 uses. The customer service number is 1-800-688-1989...we may be able to get it replaced. If they aren't willing to do anything, I'm thinking of filing a complaint with our state Attorney General because there are SO MANY complaints of the SAME, idential problem from thousands of consumers!!!!
Jan 02, 2010 | Back to Basics TEM-500 Egg & Muffin...
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Need a replacement egg poucher
Here is the cheapest egg poacher available:
http://www.webstaurantstore.com/vollrath-75080-full-size-aluminum-egg-poacher-cup/92275080.html
If you need a specific replacement, let us know the brand and model number.
I hope this helps.
Nov 15, 2009 | Kitchen Appliances - Others
Back ti Basics toaster the Egg portion does not get hot
Call the company. They will send you a new toaster -- at least they did for my neighbor.
May 10, 2009 | Back to Basics TEM-500 Egg & Muffin...
Paula deen toaster with egg cooker
the toast part works but the egg part does't
Aug 20, 2008 | Back to Basics TEM-500 Egg & Muffin...
Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster Logo
1,810 people viewed this question
Top Back to Basics Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Pierre Legault
Are you a Back to Basics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
