Question about Maytag MGR5750 Gas Kitchen Range
Digital clock on Maytag gas range doesn't keep time
At random intervals, the original clock on this MGR5751BDW Maytag gas range would be off by as many as 5 or 6 hours. Clock was replaced about a month ago. Repairman checked stove; electrician checked house wiring. Both OK. Replacement clock worked for a while, then trouble started again. At first I would reset SC to the correct time; no longer do that. I've kept sporadic records of time on stove clock (SC) and cable box (CB). Lastest data for aberration: 10/17/08 PM, SC 10:11, CB 6:00; SC 11:00, CB 6:49; on 10/18/08 AM, SC 10:01, CB 1:34. What's causing this and what's the fix? Thanks :-)
rickzilla
  • 706 Answers
SOURCE: circuit blows and when we get it back on the fault code says H3
Hello rcgrecco,
I will try to assist you but will be making some assumptions based on your problem description. First off, when you say it takes a few tries torest the fuses.. are you referring to circuit breakers? or changing out fuses a few time until it begins to work ok? In either case, the fact that it is drawing more current than the service ( fused or circuit breaker protected implies that you have one of two problems, 1. undersized service ( meaning the fuse of circuit breaker which protect the circuit is under-sized) or 2. a short internal to the stove or receptacle that supplies power to that stove.
I would approach a solution in this manner. Remove or disable power to the stove then open the wall receptacle and ( with power verified and off) tighten all wire junctions.. I have seen cases where a loose wire termination becomes resistive and then in order to meet power demand at the burner, more current is drawn which in turn causes the breaker or fuse to trip..) I would also check the terminations at the point of entry for the power cord at the stove. Make sure all the wire terminations are tight. Once you've done that, try turning on one burner at a time and see if the service remains on or trips the protector ( fuse/breaker) I wouldn't use the oven until I verified that each burner works OK.. then try the oven by itself.. and add a burner .. then two.. ( the point being is to try to determine if you have one of the heating elements shorting. 12:00 flashing is the default time setting after power is lost and restarted. I am almost 'questioning your electricians findings" since circuits do not trip unless there is a fault ( too much current being drawn or the service is under-sized for that oven) or... the circuit protection in and of itself is failing due to marginal components. The fact that it is getting worse suggests that whatever was shorting is shorting more frequently.. perhaps a heating element is shorting after it gets hot.. they are typically resistive elements and it is possible for a short to develop between the core material and the protective jacket.. I hope that helps you... or at least provides a few ideas on where to look...
Regards,
Rick
Posted on Feb 16, 2009
SOURCE: I was setting the clock
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Posted on Mar 05, 2009
philbran
  • 242 Answers
SOURCE: change time on stove held clock button and got a 5Ab & can't chng
Loof for the tech. sheet in the unit , either in the control panel [top] or the bottom under the drawer. It should tell you how to enter different modes on your range.
Phil
Posted on Apr 10, 2009
jsrock516
  • 5911 Answers
SOURCE: How do I set the clock on a Maytag gas range, I
If your range is the same model as you posted this question under, the time is set by pressing the "CLOCK" button. The word "TIME" will begin to flash on the display. Using the keypad, press the corresponding numbers of the current time.
NOTE: If the oven has been programmed, or is in use, you cannot change the time. Cancel all other functions before attempting to set the clock.
If the model number is not correct, please post back with your correct information so that I may be able to provide you with better assistance.
Posted on Nov 01, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Posted on Jan 13, 2010
Nov 01, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Error message and alarm
These are the fault codes for your unit
or
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
Kitchen range random chatter noise
could be clock motor or fan motor keeps running.
Jan 24, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Maytag clock
my screen shows locked on my oven and the oven door won't open
Nov 03, 2008 | Maytag MGR5751AD Gas Kitchen Range
Clock
More than likely the EOC will need to be replaced unless you don't care what time it is and the other funtions are working properly. (electronic oven control)
Jun 18, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Mar 23, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. Catriver..post back.
Oct 12, 2006 | Roper FGP300 Gas Kitchen Range
Maytag MGR5750 Gas Kitchen Range Logo
112 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
