Question about Epson Stylus Photo R220 InkJet Printer
Epson R320 carriage jammed
My Epson R320 Ink Carriage slammed to the right side...and won't release. Help?
thanks
  • highaltp Oct 21, 2008
    Thanks so much...but, the carriage seems to be locked. I just got the top plastic cover off...but, can find a "release" switch.
    Again...i really appreciate the help!
    Thanks! I was able to find a squareish white, nylon latch...released! Now...the job is to get it all synced up again!
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Posted on Oct 04, 2010
    Master:
  • 409 Answers
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Posted on Oct 21, 2008
Carriage Jam for HP 6210 all in one printer
It a service faulty. you can batter replace it solved the problem.
Jun 12, 2013 | HP OfficeJet 6210 All-In-One InkJet...
Lost my instruction book how do i change ink cartridges in Epson r320?
just press the ink button (with the drop symbol) once and the carriage will move to change ink position, you can now change the cartridge. when your done, just press the ink button once again.
Aug 15, 2010 | Epson Stylus Photo R320 InkJet Printer
Ink cartridge slams from side to side and lights
Epsons often experience this odd problem. This is a sort of tempory fix.
turn printer on allow carriage to leave its base and disconnect the power cord.
Clean the rails the cartridges run on. You should notice the cloth comes away with black stuff.
Use a small amount of sewing machine oil on a cloth and wipe the rails again ( or small amount of wd40 on a cloth.
Slide the carriage along and back a few times. then return it to home and reconnect power cord and turn on. That should get it to behave for a few more weeks/months. If it continues, then the head is damaged and will have to be renewed or buy a new Canon Printer. ( NOT EPSON)
Please rate my help++++Thanks for using FIXYA
Jul 01, 2010 | Epson Stylus C88 InkJet Photo Printer
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson R320 "General Error" message - unable to clear
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson CX2900 problem
HI,
Try to reset it :
SSC Utility has the latest version SSC Utility 4.30... This time it can now reset the Epson Stylus CX2900...
Download the latest version and Install it...
Under Configuration...
Select Installed Printer (EPSON Stylus CX2900 Series)
Under Printer Model
Select EPSON Stylus CX2800...
I hope this will help you. Link
Aug 02, 2008 | Epson Stylus C84 InkJet Printer
Epson 1280 Solid red mainteance light
Hi-
Is iot on the position where you can install the ink cartridge? try turning it off and unplug it from power supply then after 10mins replug and turn it back on. keep me posted, but if it will do the same thing chances are there is something wrong with the belts on it, better have it fix or have it check. Thanks for using fixya!!
Jun 26, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
360 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
