Question about Kenmore 24032\24036 Top Load Washer
Want to remove the agitator to look for my lost diamond ring
I'm pretty sure that my ring went through the wash in my series 80 Kenmore washer model # 92283100. I want to remove the agitator to look for it but can't even get the cap off. Also, are there other places in the washer that a ring might be lodged?
  • 1 more comment
  • adevlin22 Oct 22, 2008
    The larger holes on the agitator have something like a rubber liner underneath them. My husband doesn't think a ring could pass through those holes because of that liner so he stopped there and didn't go further to look at the pump. If i thought there was a chance that the ring could be under the pump I would call in a service person. Any comment on those larger holes on the agitator?
    I appreciate your taking the time to respond but what I need to know is if the 4 larger holes on the agitator, which appear to have some sort of membrane under them, would allow a ring to pass through? The other holes are way to small. The question is, is it worth taking that membrane off to check the pump to see if the ring is there? Is there anywhere else in the washer that the ring could be lodged?
  • adevlin22 Oct 25, 2008
    Your last comment convinced me not to take the washing machine aprat to look for the ring and, luckily, I found it the next morning (not in the washer at all!). Thanks again
    Scholar:
  • 121 Answers
If your ring was small enough to go through the holes in agitator, then there is a pump under the washer that has plastic and rubber parts that can be removed. Especially Kenmore which should have a rubber boot type looking thing under the pump. You can't miss it.
Posted on Oct 21, 2008
  • Edward Boukater Oct 22, 2008
    It all depends on the size of your ring. If you think that it will fit in the hole chances are it's down there.
  • Edward Boukater Oct 23, 2008
    If there is a membrane covering the holes that's so nothing can get through there like socks and underwear and diamond rings. I don't think it's in there. But if you can't find your ring anywhere else then it would be Worth your piece of mind to have a look.
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
Nov 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 80 series leaking....plastic tub cracked on the bottom
if you removed the large nut (round with four notches cut in it ) then tub should be free. sometimes these "rust together" on the hub. wd40 and a hammer to knock it free. try rocking the basket to break free. you did remove the tub ring(white plastic part on top), right?
Apr 28, 2009 | Kenmore 22422 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Mar 09, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
292 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
