Question about Kenmore Oasis HE 27082 Top Load Washer
I keep getting an F 51 error code on my washer?
Please help me am always getting F-51 error code what do I do?
  • Anonymous Mar 12, 2014
    Error code F 51 is showing even after clearing.
  • 62 Answers
If not under warr. You must replace sensor on bottom of tub along with the wiring harness. This is a common problem with these.
Posted on Oct 22, 2008
What codes are these to 1994 geo panel blinks two numbers 42 and 51
Ignition bypass error.42,incorrect MEM-CAL 52.
Aug 24, 2014 | Cars & Trucks
Washer does not work it goes into error code f51
F 51 error code means the computer cannot detect that the motor is turning properly. The most common cause of this problem is an article of clothing has gotten between the basket and tub and is stopping the basket from turning freely. There are several other possibilities but I have seen this cause an F 51 error code many times. Hope that helps.
Aug 29, 2011 | Maytag Washing Machines
F-51 code
Motor RPS Failure--F then 51 flashes when there is a motor rotor position sensor(RPS) senses rotation after stop command.F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT.But if that does not help then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Sep 01, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Error code 51
there is a rotor position sensor failure.look under the top hood of washer on the inside of the front of washer and you will find a tech sheet that will help with this problem use a flat blade to push two clips in to get hood up.
Jan 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool wtw6200 cabrio washer error message f 51
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Dec 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis HE 27082 Top Load Washer Logo
512 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
