Question about Technics SA-AX530 Receiver
Surround problem with sa-ax530 reciever
My SA-AX530 Technics Reciever outputs in stereo and 6 channel discrete mode but not in surround or Sound Field Control. Wondering what I can do to fix it. Thanks
3 Suggested Answers
mlapres
  • 757 Answers
SOURCE: No surround Technics SA-AX530
There is likely separate gain controls for your surround channels on this receiver and they are probably set at -10dB. Enter the setup menu labled "level" and increase the amount for each channel equally.
Posted on Jun 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hello, What must have an
Since it only drives a self-powered subwoofer's amplifier the impedance of the downstream speaker on matters to THAT amplifier.
Posted on Aug 14, 2011
dunnbiker
  • 8546 Answers
SOURCE: Can I use any cable
That would depend entirely on your unidentified subwoofer and what IT needs. The Receiver puts out a usable Subwoofer feed on an RCA jack. That would suggest an RCA Cable, huh?
http://exaudio7.netserwer.pl/allegro/technics/sa-ax530_2/sa-ax530_7.jpg
Posted on Sep 03, 2011
Technics SA-AX530 all modes not working - no sound
Not a good sign. There should be a click a few seconds after you turn on the unit. That says the output section is OK. If there is no click, you need repair. Perhaps only some fuses inside, but it could be worse.
Also make sure that the speaker switch is in the right position, like A, not A+B. Also the headphone jack can silence the speaker.
Make sure that ALL switches are in the right position.
Dec 17, 2013 | Technics SA-AX530 Receiver
Can I use any cable to connect the subwoofer, for a Technics sa-ax530 receiver
Sep 03, 2011 | Technics SA-AX530 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Jun 18, 2009 | Technics SA-AX530 Receiver
Problem with speaker wires making contact in back of reciever on
Open up the receiver and check for poor solder connections @ the spkr junctions.
If you can solder, then solder a pin that is THICKER than the wire to it, the Bose wire is fairly thin and the spring clips don't clamp to heavily to thin stuff.
When you push the surrounds in you bottom them out in the connector. Having a thicker wire will eliminate the problem, use a piece of 12ga solid wire from house wiring. Make as many as you need and shrink tube all connections after soldering. Use White for + and Black for -.
Larry
Jan 29, 2009 | Technics SA-AX530 Receiver
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
Connecting tv/dvd combo to reciever to obtain surround sound
look for a connector that reads "Optical"..if none, then not supported.
Jun 08, 2007 | Technics SA-AX530 Receiver
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Technics SA-AX530 Receiver Logo
155 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
