Question about RCA D52W19 52" Rear Projection Television
Flyback wires hi, am preparing to replace the flyback on my hd52w59 but don't see how the 2 leads on the flyback come off; i can see that the other ends go the underworld of the unit and it doesn' look like fun trying to get to where they connect inside the tv. does the new flyback come with wires attached?? any info appreciated h2
    Problem Solver:
DEPENDING ON WHICH FLY BACK YOU GET. THE ONE I GOT DID NOT. I'M LOOKING FOR THE WIRE NOW.
Posted on Dec 18, 2008
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Power button lights three times when pushed and unit makes squealing noise each of the three times the light comes on then nothing. No power, no light, etc...
replace the flyback which is the 270125 flyback. You can get the 270125 Flyback repair kit at the following link which contains the flyback plus detailed instructions on CD
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
New Flyback old one wont come out
if you dont know what the second anode is you should not be working on this set. on some the lead comes out of the flyback some it has to be removed from the hv distributer block. output transistor probably bad also......
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replacing the flyback
If your model is a HD52W59 the wires are part of the new transformer and have to be changed at the tripler and screen control block
Jan 21, 2009 | RCA HD52W59 HDTV Projection Television
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Screen Flickers
This not a DLP set and does not have a bulb that the customer can replace.
It may need a firmware upgrade if avaiable.
Oct 21, 2008 | RCA HD52W59 HDTV Projection Television
HD52W59 Convergence problem
DId you solder the flyback transformer connections..... This is the main reason these fuses fail. THe flyback is the big black component next to the fuse. poor solder connection cause oscillations.. this fuse is only .4 amps whish dosent stand up to that well.. resolder these pins on the flyback.... the first time i replaced this fuse i failed to solder played well for 2 days then came back blown again
Jun 10, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 convergence problem
there is a special fuse on the power deflection board. when blown this causes the processor to think it a crt tv. The fuse calle fl231 is a small brown rectangular fuse in the middle of 3 just like it next to the flyback transformer the big black thing with the large red wire comeing out. ussally it blows because the solder connections on the flyback. WARNING high voltages are generated by flyback. be careful please
Dec 27, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W19 52" Rear Projection Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
