Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Silverware becomes cloudy and is difficult to polish
After several washings silverware becomes dull and cloudy. This condition is almost impossible to remedy after repeated washings. There is no polish that cleans it quickly. This situation seems to build up and get worse after time. We did not have this problem till we purchased our LG.
All conditions are the same as with the old washer.
Many thanks,
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Hard water is the reason for the white residue spots. There is a new product out at www.dishwasherfilter.com that is made specifically to fix this problem. It filters the water going only into your dishwasher leaving your dishes spot free with every load. It is very affordable and guaranteed to work or your money back. You will love the way your dishes look after the very first load.
Posted on Jul 30, 2009
  • 423 Answers
The new water-conserving dishwashers, including the LG LDF 7811 are very sensitive to the dishwasher soap that is used.
If you notice white staining beneath the soap dispenser at the end of each full wash and possibly undissolved powder remaining in the dispenser, I recommend you stop using that powder and buy a box of Electrosol or Cascade powder and use it in place of what you currently use. Avoid using gel or tablets in all dishwashers.
I experienced very similar problems with the LDF8812 that I personally own. First step to fix was pulling the filter (10 phillips screws) rinsing the filter as best possible, remove all debris. Replace filter and spray arm.
Place a bowl filled with white vinegar in a bowl on the rack of the empty dishwasher. Run a quick wash cycle to the end.
Look closely at the RinseAid cap inside the door, remove it and turn the little dial to a lower number. Over time, adjust it up if dishes are not drying properly.
Use the dishwasher normally - do not overly pre-rinse the dishes because the food particles are actually used during the wash cycle to help clean the dishes. Also, do not over load the dispenser cup with soap. A Tablespoon will do it. If you run out of the rinse aid, feel free to use white vinegar.
Posted on Mar 31, 2009
Replacement silverware tray
Best Dishwasher Replacement Baskets - Amazon.com
www.amazon.com/...Replacement-Baskets/.../2232353...
Amazon.com, Inc.2. GE WD28X265 Dishwasher Silverware Basket · 4.6 out of 5 ... Whirlpool 6-918873Silverware Basket · 4.7 out of 5 ... 4. Whirlpool 8531233 Silverware Basket.
Nov 24, 2015 | KitchenAid Architect? II S SERIES KUDS03FT...
Door will not shut when upper silverware holder is in
Make sure you are installing that silverware holder properly. The little tabs of the silverware holder are supposd to go over and around the mating bars of the upper rack. Barring that, your upper rack may be pulled (bent) out, and you may have to push it (hard) to get it back in shape.
Oct 30, 2014 | General Electric Adora GHDA670N Built-in...
Is it more expensive to buy stainless steel or silver silverware/flatware?
Silver is more expensive than stainless steel. Silverware pricing is high as silver is a precious metal and silverware is considered to be an heirloom. So if price is not a problem for you then silverware is the way to go. But if you want some thing more cost-effective, then choose stainless steel.
Read more at Buzzle: http://www.buzzle.com/articles/stainless-steel-flatware-vs-silverware.html
May 06, 2013 | Home
What is gold silverware?
Gold silverware, more properly gold flatware, is flatware which includes gold in its construction. Pure gold silverware is extremely unusual, because gold is such a soft metal that it will be easily damaged in routine use. More commonly, the flatware is gold plated or accented with gold. Department stores and companies which manufacture flatware often carry several versions of gold flatware, which can be customized with monograms and crests as desired.
-wisegeek
May 06, 2013 | Home
Our Maytag MDB9100AWB is 5 years old. Have had repairman out several times. Problem is a light cloudy scum on everything. He has replaced several items, has had us clean parts and fixtures, etc and even...
There are three typical causes of chronic cloudiness on glassware/dishes.
  1. The incoming water may be too hot. Make sure the water is at or below 140 degrees F.
  2. Test to see if cloudiness is removable by hand cleaning or soaking for 5 minutes in white vinegar. If it is removable, it's due to hard water. Use a good quality detergent, and match the amount of detergent used to the water hardness and use a rinse aid. (Some low quality detergents clean poorly and leave a film.)
  3. Glassware may be etched, due to too much detergent, too high water temperature, or pre-washing. Etching is not reversible, so it's important to correct the problem promptly.
Hopefully these hints will help you to home in on the problem.
Dec 27, 2010 | Maytag MDB9100A Dishwasher
Silverware is dull and filmy
How is the water hardness in your area. If my watersoftener is low on salt I get this problem. Also you could try a rinsing agent in the little spot beside the dish washing detergent. Some detergents I find also leave a film. I find Cascade works the best.
May 26, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
Hard build up of cloudy film on glasses and silverware ruined.
Can you try using vinegar on one of the silverware pieces for me and let me know if that helps? Sounds like it may be a hard water issue.
Sep 26, 2017 | Kenmore Dishwashers
Not cleaning dishes, leave a cloudy film on silverware
the problem is hard water. you need a dishwasher filter and your problems will be solved. you can get one at www.dishwasherfilter.com and it is guaranteed or your money back. you will love the way your dishes come out.
May 31, 2009 | GE Dishwashers
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
383 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
