Question about Sony KV-35S40 TV
Sony trinitron KV-35542 35 inch Picture goes out after 1 or 2 min but still has sound
I have a sony trinitron KV-35542 35 inch. It turns on the picture is great then after a couple of minutes the screen goes blank but I still have sound. If I shut it off and then back on the picture comes back on for a couple of minutes and then goes back off. Is this something I can fix?
Thanks
Al
  • 556 Answers
SOURCE: Sony Trinitron KV-1670 TV
go to web site www.serviceinfo.com it is available you will have to download.
Posted on Sep 29, 2007
  • 4234 Answers
SOURCE: My sony Trinitron KV-32S42 keeps blinking on and off
This can be a symptom of the picture tube starting to fail or a power supply problem. Can you please verify the model number and I'll then be able to give you a few options.
Thanks,
Dan
Posted on Nov 11, 2008
  • 106 Answers
SOURCE: how do i adjust the vertical hold on my sony
take the back cover off there shoulde be one or more little knobs so you can adjust the tv
Posted on Mar 17, 2009
  • 1348 Answers
SOURCE: Sony Trinitron kv-27HFR blurry
the picture tube is gone.
i repaired 150 sony xbr and kv series with that problem.sony has a single gun not three and has a great pix,but burn out faster.
there is a main screen control that you can adjust ,but the tube is gone.
on the back of the crt there is 3 gun drives r g b .
turn the color all the way down so it is black and white.
if there is a green ore purple tint,one gun is out of balance.
ajdusting the r g b controls so that black and white is normal is what you want to do.
the crt board has the screen bias voltage 800volts on it so be very careful and use an insulated screwdriver to adjust the drive controls.
Posted on May 13, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Kv-25x5u picture goes off but sound still there, red light at front flashes 4 times every 5 secs, picture comes back on after 15 mins
if you are a tech the set is having problem in the vertical and horizontal circcuit...check IC 1509 and Q1505.good luck.
Sep 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My sony wega tv will not stay on,it goes on to standby alternating between a green light and a flashing red light.I cannot find the manual. What should I do?
i have a 50 inch wega that i just replaced the lamp. it wont stay on. i lose the pictuer and sound after a min or so then lose it for a min then it comes back on???
Jun 26, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking Sony Trinitron with no picture or sound
you have a drive ic problem. ic 600, r640 and modification needs to be performed. Take to a Sony servicer. Est.$150 parts and labor
Dec 30, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Picture stays on for 3 mins, then slowly disappears
sounds like the filament of the picture tube is losing voltage. normally this would be caused by a bad/broken/cracked solder connection. If this is the problem, it may not be too dificult to fix if you have the soldering skills and know what to look for.
Dec 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
FV-27KV300 WEGA 27" Sound Problem
adjust the sound IF in the tuner or in the IFblock
May 03, 2008 | Sony FD Trinitron WEGA KV-27FV300 27" TV
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Sony KV-35S40 TV Logo
810 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
