Question about NetGear WG111T 108 Mbps 802.11g Wireless USB 2.0 Network Adapter (NETWNGWG111T)
Wireless adaptor having installed the adaptor,i have to keep taking it out and putting it back in several times before i can get on line,so i uninstalled and reinstalled and still have the same problem,if i leave the pc to go to sleep,when i return the adaptor is dead,and have to go through it all again,surely i shouldn't have to keep doing this.please help.
    Genius:
  • 1,913 Answers
Check your power supply source .adapter waltage laos checl earthing properly.
Posted on Oct 21, 2008
Ethernet controller
Most times, with a modern computer, it will automatically install or re-install the drivers for your Ethernet as soon as you turn it on. Assuming this is not working for you, and if you happen to be on Windows 7, you get into your Control Panel, System, Device Manager, Network Adaptors.. find your Ethernet controller there, double click on it, and you will have several options in dealing with the driver. Keep after it. You'll figure it out..
Dec 13, 2013 | Computers & Internet
I installed the compact wireless g usb adapoter on a desktop in basement of my house approx. 2 years ago and it was fine. I need to tell you that at that time I had satilette iwth wild blue and a linksys...
My experience is limited with such things.
Connecting the computer to the router with a cable I found was an instant success with three different routers and two different service providers (and several computers).
I fitted a couple of generic wireless adaptors also without incident. Each wireless adaptor arrived with a mini disc and instructions to load the drivers before plugging in the usb adaptor and ten minutes larter I was looking at a list of available wireless networks and being asked to choose one and the enter the password that is written on the underside of the router.
Once I used the Windows wizard to set up a wireless network and similarly had no trouble. I don't think it is necessary to configure the computer to a particular modem and I have not heard others speak of such a thing. Apart from needing the driver for the usb wireless adaptor there it all should happen automatically
Once the driver is installed and the adaptor plugged in, it should be obvious whether it is working because it should detect nearby wireless networks - but it won't connect with any of them unless you click on a particular one. It will only be possible to connect to open wireless or the one or ones you have the password for.
Once the computer is connected it should get the IP address automatically and then connect to the internet..
I have a sneaking suspicion you are thinking too deeply about this. The internet these days is almost foolproof - it has to be for me to get it to work.
Perhaps your operating system is seriously corrupted...
Mar 08, 2017 | Linksys WUSB54GSC Compact Wireless-G USB...
Hi, I have just purchased a new WNA-1100 wireless adapter. I have installed it with no problems, but when it asks me to insert the adaptor and press next, it just keeps saying 'detecting adaptor', for as...
Got this fix off of newegg, and it works for XP
Install the updated software package from Netgear. Go into C:/ Program Files/Netgear/ and copy the Driver folder. Paste to your desktop or wherever.
Uninstall the Netgear software. Plug the wireless adapter back in, let Windows locate, and point it to the XP folder in the drivers folder. You're up and running. ^.^
Oct 23, 2010 | NetGear WNA1100 WirelessN 150 USB Adapter...
My wireless wont work on my laptop
First of all let’s check if you have a wireless card in your laptop.
1 Right click my computer 2 click properties 3 Click hardware 4 Click device manager.
Look down the list and click the + on network adaptors you should see two adaptors 1 a Ralink RT2500 Wireless LAN card, or a 2000 or something like that to show it has a wireless card installed.
The second adaptor is a VIA Rhine II Fast Ethernet adaptor this is for the cat5 cable that would be connected direct to your modem for going on the net direct.
If there is no mention of a wireless card you have not got one fitted, if one is mentioned but it has a yellow mark next to it the card is not working has it’s not got a driver installed.
Let’s deal with the easy one first, card installed yellow mark i.e. no driver.
Connect the laptop via a cat5 cable direct to your modem or get on the net somehow.
Type in Fujitsu it will bring up lots of options click Fujitsu Siemens scroll down to support Fijitsu and it will take you to welcome to support page click on drivers and downloads.
This will take you to a page that you put your serial number in then all the drivers will be listed and you can download the wireless LAN driver.
Once the driver is installed you should get onto the net via wireless.
If no card is installed you can get one for a few £s off EBay. (teastheword will have one)
To install it read the post I put up on changing the COMS battery, you have to remove down to the RAM cover i.e. power strip keyboard RAM cover.
You should see two wires one black one gray the gray clips to the main terminal of the card and the black to the Aux, the card slots into the mother board.
If the laptop has a card and the latest driver installed and still will not connect it’s the Arial behind the screen or the mother board which is a common fault. I could talk you through changing that but at this stage it’s really a shop job.
You can still go wireless by purchasing a USB stick wireless adaptor this will act as you wireless card (Net gear wg111v3 or equivalent. Just plug it in load the driver and connect.
You would then have to load the driver as above.
Hope this solves your problem or helps.
Jan 16, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My wireless adaptor does not work properly
These wireless dongles can take time to conect after pc starts some times they take up to 3 minutes to configure. What you could try doing is changing the brodcast type on the main modem and reconfiguring the dongle on the other pc to conect might work out faster for conection and better.
Nov 30, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
D-Link wireless adapter will not pickup my
you may need to check the access point rang/availability. otherwise change your wireless adaptor. re-installtion of windows also solve your problem.
Sep 12, 2009 | D-Link WUA-2340 (ASKU55774) Wireless...
I don't have wireless network on acer aspire4715Z
The Aspire 4715 comes with Wireless OPTIONAL. Your system obviously wasn't bought with a pre-installed wirelss card. If you want to go wireless, you will need to buy a wireless card/adaptor seperately.
Nov 29, 2008 | Acer Aspire 4720 Notebook
New ASUS G50vm-x1 from Best Buy
Unfortunatley laptops have everything "built in onboard" which is to say to fix it you need to replace it. Take it back and try another one. The other option is to disable the wireless adaptor and get a usb wireless adapter to take it's place.
Jul 26, 2008 | Computers & Internet
After installing cd and following directions to install my Linksys wpm300n wireless-n pci adaptor the directions say to power down pc,installcard hookup antenna and re power up pc.but i get no futher set...
Click on Start - right-click on my computer - click on properties - click on hardware - click Device Manager
Look for your wireless adaptor in the list. Probably under Network adaptors. If it is on the list and there are no yellow question marks or Exclamation points next to it then you have successfully installed the device.
If there is an item that says unknown communication device with a yellow question mark next to it (?), put the set up disk back in and reinstall.
Most of the time when you install a new device in a pci slot, you must install the device physically in the computer first before running setup.
May 03, 2008 | Computers & Internet
Wireless Network?
The modern laptop and Wii will be no problem. Windows 98 will work but it can be much trickier to set up.
Parts needed
1 x Wireless Router - You can pick up a 2WIRE Router from around £20 on eBay
3 x Wireless LAN Network Adaptors - Around £20 each.
Firstly, the Router. This bit connects to your telephone line and broadcasts your broadband signal by radio and allows several computers to use one service. When you buy a router make sure it includes installation software. You can install routers without, but it's a whole lot easier if you have it.
Next you need to be able to receive the broadband radio signal on your computers and Wii.To receive the signal you need Wireless LAN Network Adaptors on each device. Network Adaptors also have software, which allows you to install the drivers needed.
Your laptop may already have a wireless adaptor built in.
You can check this by clicking
Start\Programs\Accessories\System Tools\Communications\Network Connections
Then see if a Wireless adaptor is present. If it isn't, you can install one inside the laptop by buying a laptop wireless network card. Easier, is to buy a USB Wireless LAN Network Adaptor which just plugs in to a USB socket on the laptop.
Look for LAN Network adaptors that are suitable for the Wii and a separate one suitable for Windows 98. Most will be ok for the laptop.
Install the router first. just do what the software tells you, then install the LAN adaptor drivers on each device you want networked.
Finally, make sure you secure your router signal. That stops the guy next door using your network and offers some security from hackers. Your router will include a firewall and you can set up a key code that your adaptors will need before they can connect. Unless the guy next door has the key, he won't be able to use
your network and play your MP3s...hoorah!
Follow the instructions given in the software to set up a WPA or WEP security key.
Great fun, you'll love it if you can get it all going.
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
