Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Wireless button just wondering if you can help i have recently had to restore my laptop because i seem to have deleted whatever makes my wireless button work the wireless adapter seems to be working fine but i have no way to turn on the wireless function anymore
  • itphobe Oct 24, 2008
    cheers for the get back. yep re installed the wireless driver my wireless seems to still be working i just cant turn on the wireless function, when i run diagnostics to find a solution it tells me its working fine and to turn on my wireless button but it quite simply does nothing when i press it and i cant find any other way to turn it on. cheers
    Genius:
  • 1,124 Answers
Did you install the wireless drivers?
Did you connect your device to your network?
Did you see any network available?
Posted on Oct 21, 2008
Accidentally deleted files
Do a system restore. Go to Start or the Pearl Button or Windows Button. Click Programs > Accessories > System Tools > System Restore.
Select a restoration point. Make sure that it is before you deleted the files. Launch it and check if it's going to work or not. Come back to me if you need help
David
Jul 26, 2013 | HP Mini Computers & Internet
Wondered i f you could help..My daughter has an Easynote TJ67 laptop with Windows 7& seems to have changed the default access programs somehow... Everything now seems to be now set to Internet...
You can do System Restore to bring back previous settings, how?
Follow steps below:
1. Navigateto the Start -> All Programs -> Accessories -> System Tools program group.
2. Clickon the System Restore programicon.
3. ClickNext > on the Restoresystem files and settings window.
4. Choosethe restore point that you want to use.
Note: Check the Show more restore points checkbox tosee more than the most recent restore points. Note: Any restore points that you created, scheduledrestore points that Windows 7 created, and those created automatically duringthe installation of certain programs will be listed here. You can not useSystem Restore to undo Windows 7 changes to a date that a restore point doesnot exist.
5. Click Next >.
6. ClickFinish on the Confirm yourrestore point window to begin the System Restore. Note: Windows 7 will shut down to complete the SystemRestore so be sure to save any work you might have open in other programsbefore continuing.
Important: System Restore will not revert any of your non-systemfiles like documents, email, music, etc. to a previous state. These types filesare completely unaffected by System Restore. If your intention with this toolwas to recover a deleted non-system file, try using a file recoveryprogram instead of System Restore.
7. ClickYes to the Once started,System Restore cannot be interrupted. Do you want to continue? dialog box.
8. SystemRestore will now restore Windows 7 to the state that was recorded in therestore point you chose in Step 4. Note: The System Restore process could take several minutesas you see the "Please wait while your Windows files and settings arebeing restored" message. Your computer will then reboot as normal whencomplete.
9. Immediatelyafter logging in to Windows 7 after the reboot, you should see a message that SystemRestore completed successfully.
10. ClickClose.
11. Checkto see if whatever Windows 7 problem you were troubleshooting has beencorrected by this System Restore.
Jan 30, 2011 | Computers & Internet
My wireless button doesn't seem to be working....i press it and nothing happens...i already installed all of the drivers from the hp site but still no result:((
Im not sure how long ago your wireless stopped working..
But my first suggestion would be to do a system restore back to before the wireless driver stopped working.
You can do a system restore via , start, all programs, accessories, system tools, system restore.
Aug 03, 2010 | HP Compaq nx6110 PC Laptop
I just recently got wireless internet. It was
Hard to say what the issue is based on the information you provided.. There are actually a lot of reasons you might have lost the connection.
I'd start by verifying that you're connected to the wireless network that you set up. Did you name it? Open your network properties and see what the icon for the wireless adapter tells you:
- Are you connected? - Are you connected to the proper network? - Is your network card "disabled" for some reason? Some laptops have a disable button that overrides the card so the wireless radio can be shut off quickly and easily. Make sure it's not been tripped. Usually laptops have an LED to indicate if the wireless radio is running.. usually blue.
note1: be sure to check the "order of preferred networks" and from that screen delete all wireless networks you won't connect to somewhat regularly and/or ones you've connected to accidentally in the past. Make sure that your home network is tops in the list.
note2: if you did not create your own name for your wireless network and are still running the default name, it's definitely smart to change that. Your laptop can easily get confused with other networks in the neighborhood that have the same name.
Hope that helps.
Feb 07, 2010 | Toshiba Satellite A135-S2276 Notebook
Wireless button won't come on
Please backup all you files to a dvd or external hard drive and run system restore back to factory default settings.
After backing up the documents, restart system and hold down f11 key till you hear a beep then follow the prompt.
Cheers and rate this.
Aug 30, 2009 | HP Pavilion dv4000 Notebook
D Link WNA 2330 wireless adapter not lit
Try to update the driver for the wireless adapter. Here is the link for that: http://www.dlink.com/products/support.asp?pid=472&sec=0#drivers
If this solution solves your problem, please rate me.
Apr 03, 2009 | D-Link Rangebooster G Notebook Adapter...
Model = Philips freevents X50 NoteBook F12DT Say, I wonder if you can help? Clearing up some space, deleting some old 'files' from 1995, I thought I was safe. It appears I may have deleted the Drivers...
If you have only done this recently, have you tried restoring your laptop to a date prior to losing the drivers. It does mean that any other changes you have made will also be restored so any updates will have to be done again.
Jan 25, 2009 | HP Pavilion ZE5730 Notebook
My mum and dad recently bourght me a toshiba L40 laptop. I downloaded msn messenger onto my laptop and someone sent me a trojan horse. My laptop started to get weaker and i started to lose things off it....
Hello ,
You still need the reboot disk to restore you computer If you have a back up of all of your files the you can repair the windows . if you want a reboot disk contact the seller or manufacturer .
Please rate me .
May 14, 2008 | Toshiba Computers & Internet
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
265 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
