Question about HP Computers & Internet
My computer laptop makes is noisy while operating and gets so hot that i cant hold it after a short time having it turned on.
  • hellecool Oct 21, 2008
    i dont know about ram. cpu? i dont understand where to go and type "chkdsk /r ".
    Genius:
  • 1,913 Answers
Put extra fan for cooling also check your ram .may be there is heatting event shut down the cpu.
also check your harddisk.go to run type there "chkdsk /r" this command recoverd the harddisk if it has some bad issue.
Posted on Oct 21, 2008
How do i test fan
Connect the transmit antenna output to a "dummy load" (such as a 50 ohm resistor network in a gallon can of mineral oil), turn the output power to max, operating mode to CW, and hold the key down with a weight. The output stages should get hot enough to turn on the fan in a minute or two. You might need a flashlight to see whether or not the fan is turning, since it's supposed to be quiet and may not turn as fast (and noisy) as a computer fan. You'll want to make sure that the dummy load can handle the power, and that the SWR is low to begin with. If the oil gets warm before the fan turns on, the fan probably isn't going to turn on. Stop.
Jan 08, 2014 | Yaesu FT-902DM HF Transceiver
Fan noise loud and always present
If the fan is very dusty that an cause a lot of noise as it will be unbalanced. If the fan is on all of the time, maybe the bios requires updating. There may be a GPU issue and that will make the cpu run hot.
Jan 03, 2014 | Toshiba Portege R400-S4831 - Core Duo...
Hang problem
Computers, no matter the make or the model, have a tendency to freeze up. This typically occurs when you overload the RAM on the computer and the laptop can not process any more information. When your laptop freezes, you are not left with many options, so you'll you need to restart the system.
1.Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
2.Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
3.Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
4.Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
5.Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
I hope you find it very helpful.
Aug 26, 2011 | Computers & Internet
I am using acer aspire 5052ANWXMi and somebody has changed my bios utility password and now I cant enter set up..Asmy operating system is nt working I cant boot from Cd to install it as it needs bios...
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battery, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battery & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Dec 18, 2010 | Acer Computers & Internet
The fans on my Sony PCG-K33 are loud and there is a lot of heat coming from under the laptop and out the vent on the left side of the computer. The problemdid not exist until did a complete uninsall and...
Fans are usually noisy due to a build up of dust that's collected on the fan blades.
The best way to clean them is to get a can of compressed air and give short blasts through the air vents, also turn the laptop upside down and give a couple of blasts the CPU fan grill.
Alternatively you can get a clean, stiff paintbrush to clean the fan blades and blow through the air vents to remove any dust.
The laptop won't get as hot or noisy if you clean the air vents and CPU fan blades regularly.
Regards.
Aug 20, 2009 | Sony PCGK37 Notebook
Laptop won't turn on.
check your power adapter, it may have failed. try it with the battery removed incase the battery has shorted cells.
Jul 24, 2009 | Dell Inspiron 1501 Notebook
Noisy laptop
If the noise is always coming (when no application is running) then there might be the issue with the processor fan cleaning.
Mar 05, 2009 | Acer Aspire 4315-2963 Notebook
Hp dv6000 3 beeps on start(1 long and 2 shorts)- no display present what that mins, what code is this and how to proceed furder ?
3beeps means display adapter/vga adapter faulty, send to HP.There is an extended year warranty provided by HP for this fault...it is related to the AMD boards with Nvidia chipsets. It's an overheating issue. Mainboard will need to be replaced. If not your display then your wireless will bomb out. This is on all DV6000&DV9000 laptops with the above mentioned setup.
Jun 26, 2008 | Computers & Internet
Noisy fan?
This is normal.. It is keeping your computer cool when it gets too hot.
If you like this answer please rate it as a FIXYA.
Jun 06, 2008 | Acer Aspire 3050 Notebook
Averatec 3200 PC is too hot and noisy
I strongly suspect that is the fan. Unfortunately it is necessary to open the laptop and replace it. Try to spray some air on the vent to clean it but I bet it needs to be replaced.
Oct 19, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
