Question about Bunn CDBCF 35 Coffee Maker
Electrical wiring for 120/208 service as opposed to 120/240 service
I'm trying to figure out how to wire this coffeemaker for 120/208 service. The manual states that "model 35 requires 3-wire, grounded service rated 120/208 or 120/240 volts ac, 20 amp, single phase, 60 Hz.", and 240 is not an option in the location it's going into. I would like to know how to connect it internally, what type of cord toget, and what type of plug cap to get (and how to wire that as well). Thank you for any and all help.... the outlets in the location (office breakroom) are all standard, and I was thinking of plugging it into where the fridge is as that is for sure rared for 20 amp.....
  • Anonymous May 12, 2009
    I have the same model and am trying to convert to 120v for home use.Is there any way to rewire this model, or any 240v circuit for 120v? I am going to be disconnecting the 2 top warming elements, so the total amperage required will be considerably less.
I have the same problem...and it appears to me that all the electronics operate off 120V and only the heater element is connected to the red wire and gets 240V. The schematic shows that the model 15 and model 20 simply connect the heater to the white wire.
I would imagine that you can simply jumper the red to the white and the heater will get half the power but it should operate otherwise normal.
Posted on Aug 20, 2009
  • 60 Answers
Your machine requires 208-240 volts to operate with each leg being about 120 volts. Move refrigerators are 120 volts so even though you have 20 amps you probably only have 120 volts.
You can go to the Bunn website ( click on Commercial then on Publications then Illustrated Parts and Service manuals and download the manual for your machine that shows how the wiring hooks up in the machine and the type of cord the machine requires to handle the voltage.
The plug you need must match the receptacle in the wall and there are numerous 220volt plugs and receptacles on the market. Don't get a dryer plug instead try for a twist lock as they are more reliable.
Posted on Oct 22, 2008
Can i replace 4500watt elements with 5500watt on a 606 model
1) Manufacturer's warranty will be voided, and I've never seen recommendation that suggests better heating or saving money from replacing 4500W with different wattage element.
2) That being said, you have 240V water heater.
4500Watts divided by 240 = 18.75 amps
5500Watts divided by 240 = 23 amps
20 amp circuit breaker with 12 gauge wire is rated for 80% of load = 16amps
30 amp circuit breaker with 10 gauge wire is rated for 80% of load = 24amps.
3) You can use 5500Watt element if you have 30 amp breaker and 10 gauge wire.
I just bought a jp328sfss and need to know how to wire it to the breaker panel the way it is wired now it only heats water to 120 degrees F the handyman that hooked it up said there was no way to wire it...
It sounds like you better be careful for starters. I also suggest your handyman sticks to painting. In older homes a 208/240 circuit onlt had three wires. New construction and remodeling requires a four wire system. Per code, a black wire is 120VAC, and a red wire is 120VAC. In a 240VAC circuit they would be called L-1 and L-2 respectively. In order to provide 240VAC they must be on seperate phases. The bare wire in your bundle is the ground wire and is at the same potential as neutral, or the white wire in current four wire systems. If you know how to use an electrical test meter, you should show 120VAC from black to bare copper, 120VAC from red to bare copper, and 240VAC from black to red. If this is not the case, I strongly suggest you have an electrician come in and take care of it in your breaker panel. *****Electricity is nothing to fool around with if you are not absolutely sure you know what you are doing. A loose connection, a wrong connection can result in fire, serious injury or death. It's worth a service call to a licensed electrician or qualified appliance service technician to give you peace of mind, and years of safe use of your new cooktop.
Nov 18, 2010 | GE 30 in. JP328SFSS Electric Cooktop
How does one wire the T104. Can the T104 be wired via a 120 volt, 20 Amp Breaker Supply
No, the Intermatic T104 requires 240 volts for the clock motor.
The T103 has a 120 volt clock motor and will control a 240 volt load, but requires a 3-wire (with ground) supply cable [as opposed to only a required 2-wire (with ground) for the T104].
The T101 uses a 120 volt clock motor and controls 120 volt loads.
This tip may help:
Aug 23, 2010 | Intermatic T104 24h 208-277v Mechanical...
Gas oven electrical hookup issue
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Aug 02, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Hooking up the heater
240 VAC or 120 VAC, and what colors are on your heater?
Nov 15, 2008 | Fahrenheat Electric Convector Baseboard...
What size breaker do I need for a 240 volt electric clothes dryer
check on the wiring diagram. You may be looking at 2-15 amp or 2-20 amp breakers.
Nov 12, 2008 | Fahrenheat Electric Convector Baseboard...
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Bunn CDBCF 35 Coffee Maker Logo
380 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
