Question about Haier HWF05XC5 Air Conditioner
Will not start
Plugged in AC and it's won't turn on. There is power at the outlet....I've checked. The temperature is set at the coldest setting and room is warm so that's not the problem. I've tried the test button and reset button. Nothing works. My AC is actually AWF05XC5-T.
  • ballman01 Jul 02, 2008
    I have a similar situation of my AC not turning on. I tried pressing the restart and power buttons but when I plug it in, the test light turns on and off real quick and the reset button pops out. Machine does not turn on at all....
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3632 Hope that helps! ;)
Posted on Aug 06, 2007
Recharge ac
first thing is make sure the vehicle is in park, and emergency brake applied. next start your vehicle and let it get up to normal operating temperature. third turn hot/cold selector all the way to coldest. fourth turn the blower selector to MAX A/C double check its on MAX A/C and temp to coldest. the vehicle must be running for the a/c compressor to engage. when it does engage set on MAX it will cycle continuous which is needed to charge the system..
Okay so vehicles running, up to operating temp, A/c on max, cold knob to coldest.. your ready to charge the system! the kit you purchsed tells the
Jun 02, 2013 | 2001 Saturn L-Series
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
A/C runs three to four minutes; shuts off. Press, reset button, on the power cord (note: a/c inserted in power strip; and I've tried other outlets, as well).
The Power Strip may just be the problem. As far as I know, there are no manufacturers that approve the use of a Power Strip, for their AC unit to be plugged into. I know of two units, that had their electronics fried, while being plugged into a power strip. Which brings us, to the point, that your AC may already being showing the results of being plugged into a power strip. Most don't encourage an plain extension cord
Plug the unit directly into a wall outlet and try lowering the temperature by 3 to 5 degrees F, to see if it will run longer. Also, check your air intake filter and clean it, if necessary.
If the icontinues to turn OFF prematurely, it may be time to decide whether to repair or replace.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Kenmore Heating & Cooling
How can i exit from service menu code,picture is blinking and there is no sound.Service menu is appearing when set is power on. set is 14''philips vardaan . please shortout my problem.
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 13, 2011 | Philips 20DV6942 20 in. TV/DVD Combo
Maytag M7Y15F2A-D A/C - won't turn on -long beep then nothing
The beeping might be an alarm that indicates the coils are iced over by too much humidity in the air...and/or the unit is overheating etc.
shut off power to the unit for a few hours, go out somewhere if it is too stuffy inside.. see if the unit operates better when you return... I also suggest not running these things constantly, this causes some units to ice up and **** up the power..
hope the unit does get replaced, newer ones are more efficient.
Jun 02, 2010 | Maytag Heating & Cooling
Haier HWF05XC5 Air Conditioner Logo
564 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Bonded Repair
Dan Apthorp
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
