Question about Motorola Mobility H500 Wireless Headset
Bluetooth Pairing do you know the code to pair a motorola H500?
    Problem Solver:
  • 3 Answers
How you doing. the code to connect this divice is 0000. all codes are the same and CANNOT be changed.. Good luck
Posted on Oct 29, 2008
Motorola h500 sch-r350 forgot code
Starting with your headset turned off, press and hold the call button for more than 6 seconds, until the indicator light is steadily lit (you'll notice that the light will flash as if the headset was being turned on, but don't release the button at this step). You headset is now in pairing mode. Now, on your phone, go to 'Menu > Tools > Bluetooth > Registered List > Add New Device'. If the phone's bluetooth radio is off, you'll be prompted to turn it on. Do it. After a while, the H500 will appear on the phone screen. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 21, 2010 | Motorola Mobility H500 Headset
Need the code for the h500 so that i can get it to work with my blakberry
0000 - this code is default Bluetooth pairing code for the H500 and can't be altered.
Sep 03, 2009 | Motorola Mobility H500 Wireless Headset
Pairing with iPhone
Real easy go to the iphone and settings go to bluetooth and it will said in discovery mode.
then go through the pairing of your headset sontrols and the iPhone will say enter password then enter 0000 or whatever your H500 manual says.
If you have already paired the H500 with another phone you need to reset that. this is also covered in the manual which can be found online at motorola.com
Jul 10, 2009 | Motorola Mobility H500 Wireless Headset
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
How do you connect a Motorola H500 Headset to a motorola razor v3m
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Enjoy!
Jan 14, 2008 | Motorola Mobility H500 Headset
Bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Nov 07, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
62 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
