Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
I have a pin broken in my canon eos 400D
A pin where the cf card goes in is broken and it says there is a problen with the cf card. . . i really dont wanna pay lots of money to get it fixed is there anyway i can just plug a card reader directly itnto the camera and the camera use this as the card reader?
  • Anonymous Feb 15, 2009
    my canon Rebel EOS, older model has bent pins where the card goes, can it be fixed and how much will it run me?
  • 538 Answers
No, sorry. Card R/W needs to be repaired.
Posted on Mar 25, 2009
How do you replace a cf unit on a canon rebel xti
see the instructional video in youtube and proceed with common sense , logically, clearly.
God bless you
Aug 02, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D - Error message - There is a problem with your CF card- needs replacing. We have original card and also replaced with new card - message keeps appearing. What else could this mean?
Look inside the card compartment to check for broken or bent pins. Have you tried formatting the card in the camera? This will erase it so download any pictures first using a card reader if necessary.
Oct 06, 2010 | Canon Cameras
Can CF card pin be repaired on a Canon Rebel? Canon EOS 400D / Rebel XTi Digital Camera with 17-85mm Lens
I assume you mean one of the pins inside the camera body itself? This is quite a common problem and I believe it will have to be dealt with by a Canon Repair Centre. However it is not the end of the camera and is worth having done although I cannot say what the are charging at this time.
Sep 20, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
I have a CF err on my Canon Rebel XTI EOS
If your camera uses a compact flash card, then something is wrong with it. Possible causes: card needs formatting in camera (this will erase it) one or more pins inside camera are bent. Card was erased or formatted on computer instead of camera.
Feb 19, 2010 | Canon Rebel XTi / EOS 400D (body only)...
Canon rebel xti broken cf pin. does any one have the instructions or know how to repair this. I already bought the new part and would like to know how to replace it.
Hello,i had the same problem days after i bought my camera.It was my fault actually trying to put the CF card on the wrong side.Anyway i have send it to the canon service for repearing.The guys there were very nice,and changed the pins without any charges,since my camera was brand new.So my advise is to send it to any of the canon services and they will keep you inform about the status of your order rapairing.Good luck.
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D dslr will not work various CF memory cards. Error message ( replace CF card)
Using a flashlight, check thru the CF memory card reader if there are some pins that are bent, missing (broken) or damaged.
If this is the case, it is necessary to have serviced the camera to replace such pins, and inspectd for the broken pin pieces that may be stuck inside the camera, and cause later a short circuit.
If all the pins are in good conditions, may be the internal memory reader circuitry is failing, which requires also a professional camera repair service.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform the steps to repair it.
If so, You will need tools to do it, which includes the usage of a soldering iron, microscope (since requires micro soldering), and buy the CF memory card reader connector..
Best regards,
Apr 02, 2009 | Canon EOS 400D Digital Camera
Canon eos 400d. card empty but cf light flashes red
Hi! Rachel, Mark here see if i can help.
Try different cf card see if it works.
Next if that worked or not take cf card place in computer & format card. Retry in camera.
Hope that fixed ya if not comment back me happy to assist you further. Good Luck! please rate.
Mar 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon 400D CF pin broken, power down
250 is a bargain if you value your time at anything over $10.00 per.
and canon will guarantee the results.
but...good luck
mark
Aug 20, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
203 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
