Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1991 harley FXR won't start; replaced bad starter. it still won't start
91 FXR quit running. got back to the shop charged battery and tried starting. starter would roll motor over then hang up with a grinding noise. i replaced starter with new one. and still does the same thing. replaced starter relay and ingition module. same thing won't start. timimg is set right and new plugs
Battery might read the correct voltage but not enough amps to start it. change the battery.!
Posted on Nov 15, 2010
  • 216 Answers
- If the starter is turning the motor , I dont understand why u replaced the relay and the ignition....but - thats water under the bridge now .... Open the primary and check the jack shaft... put a pliers on it - pull it out and turn it 1/4 turn a few times - make sure its not binding. Take a look at the bushing on the outer primary.... may need to bevel the edges a little. Make sure the battery is charged enough to give the engine a few strong turns. Let me know what you find
Posted on Oct 22, 2008
Removed battery. Replaced starter. Reinstalled battery. Why is there no power anywhere?
Hi, Bruce you may have a faulty main fuse otherwise the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Testing the Battery and Charging System Harley Davidson FXSTC
Harley Davidson Won Start But Cranks HELP
How to diagnose no spark situation on motorcycle
Harley Davidson Softail Won Start Harley Davidson Manuals Mark Workshop
Dec 04, 2015 | Harley Davidson FLHTCUI Electra Glide...
My 91 Mercedes sel won't start. The battery is
check all wires to starter motor for bad earth.....make sure power reaching starter motor.....check starter motor isnt stuck
Feb 07, 2013 | Cars & Trucks
91 honda accord won't start sometimes-battery, a/c, starter?
Your tempermental starting problem could be the park neutral safety switch . They get worn inside an cause this type problem . Next time it won't start place gear selector into neutral an see if it starts then . The cooling running problem is probably the cooling fan timer module . From the diagram it's hard to say which side the A/C condenser fan is on. The A/C fan has blue with yellow stripe wire in the connector along with a black one . I would also suggest you have a qualified repair shop do a voltage drop test on the starting circuit .
How to voltage drop test starter motor circuit
Starter Voltage Drop These test's will find any starting circuit problem .
Mar 28, 2017 | 1991 Honda Accord
You can keep pushing it to start and hear the clicking but it will start at times and other times it takes several attempts
Check the battery for good connection if that's not it try charging the battery if none of those things work it needs a new starter
Sep 17, 2011 | 1993 Harley Davidson FXR Super Glide
I just pulled my 2006 screaming eagle ultra classic out of winter storage and it won't start. The battery had a full charge and it makes a long clicking sound when I try to start it. It's the...
Harleys pull a lot of amps starting,, Just because the battery says 12v doesn't mean the charge is handling the draw when trying to start them ,, get the battery LOAD checked,, remember also,, Harley's are known for drawing Juice when starting , thats why any dealer or shop will tell you that if you start one be sure and drive it a while,, start and stop trips eat up the battery since the alt won't keep up with the charging. when I leave mine for any time, I use one of the trickle charge units just to keep it at full
May 13, 2011 | 2006 Harley Davidson FLHTCUSE Screamin...
When trying to start my 1991 Plymouth Sundance America I hear only a clicking sound. I replaced the battery but it did not work. Can it be the alternator?
sounds like you have a bad starter.not your alternator.if the battery is good the car should start even if the alternator is bad.you can even drive the car until the battery runs low.the alternator job is to keep the battery charged.soulds like the solinoid is clicking.but no responce from the starter.have starter checked.
Dec 08, 2010 | 1991 Plymouth Sundance
1987 FXLR 80" 11-1 compression Evo Engine. S&S heads, barrels, and carb matched to a '91 clutch assembly and a Spyke starter. Have a continual problem of having the starter jack-shaft "fall" and...
The problem on your starter sounds like the "overrunning clutch" in the starter. The jackshaft cannot "fall" as the outer end of it is supported by the outer primary cover. It's engaging your ring gear, just not turning the engine. If the start spins, this means the jackshaft has been pushed into the engaged position because the starter will not spin until the solenoid plunger is in the full forward position. So, the only thing left is the "starter clutch". With a compression ratio like you have, you should be running compression releases if you wish to keep even a Spyke starter in the bike.
As for the electrical problem, it sounds like you've got a stator shorting out on you. I had one customer with a 90 FXR that was happening to. His bike would run fine for days and weeks but ever so often, it wouldn't start due to a dead battery and he'd just been riding it. We replaced the entire charging system. The only thing that we hadn't replaced prior to that was the stator. Now, if you wish to prove this, you'll have to catch the problem when it's not charging the battery. If you wish, you can purchase a voltmeter at any automotive parts house and install it on your bike. The battery should charge at 14.5 to 14.8 volts. Anything below that, the battery will slowly discharge. If you can, test the stator output. Unplug the connector at the cases. Inspect the connector to make sure the connections are in good shape up inside the plug. You need one those hold downs that keep this plug tight as well. Using a DVOM (Digital Volt Ohm Meter) put one of the meter leads on each pin in the case, put the meter in AC volts, 50 volt range. Start the engine and you should read about 25 volts or greater. If not, the stator is defective.
Good Luck
Steve.
Jun 12, 2010 | 1993 Harley Davidson FXR Super Glide
Motorcycle no start condition
first things first change the spark plugs and then make sure ya have fresh gas it as well.
May 11, 2010 | 1993 Harley Davidson FXR Super Glide
92 FXR bike will not start or even turn over
the starter solinoid is not working if it has an electric start, try kick starting it, if it won't start check the points or the ingiter coil.
Aug 08, 2009 | 1993 Harley Davidson FXR Super Glide
91 buick was running good cleaned battery cabels now will not start no spark
1.Make sure all connection to the battery are secure opposite end of pos/neg connections connecting to the starter and and ground are also secure and clean..
2.Try jump starting the car.
3.If step one or two did not correct the problem, have the battery tested and re-charge the or replace the battery if required.
4.If the above three steps do not correct the problem, before starting the car, gently tap on the starter with a small hammer, then try and start the car. If the car starts, you have a faulty solenoid in the starter, which indicates the starter needs to be replace. Please rate this solution if you found this helpful.
May 14, 2009 | 1991 Buick Park Avenue
Lands Phones Logo
728 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
