Question about JVC AV-32260 32" TV
Video will not turn off; "I2C-BUS STOP MODE" error at power up
TV is actually a JVC AV-31BP6 (Chassis A48), but I couldn't find a forum for that model. When the TV is plugged in, it automatically powers itself up. Without a cable hookup, the screen displays static as expected, but with cable attached the TV powers up to a black screen with the words "I2C-BUS STOP MODE" flashing at the bottom. Pressing the power button clears the text and brings the TV for all intents and purposes to normal functionality (picture is normal, channels change, volume control, menus, etc). When the power button is pressed either on the remote or from the front control panel, the audio shuts off as well as the channel display text, but the video continues to play. Pressing the power button again causes the screen to flash briefly before sound and channel display text return and the TV again resumes full function. Only removing the power plug will turn off the video. I have some small experience with TV repair but I'm not sure where to start with this and would greatly appreciate some advice. Is it likely that the I2C MCU is the culprit? Or should I be looking somewhere else? If so, where? Thanks in advance.
    President:
  • 3,130 Answers
Nope a very easy problem .. What it is is the relay is stuck on or closed so when you plug in the set the power comes up But the micro hasent told the rest of the set to work yet. So when you hit the power button. its just like you hit the power and it activated the relay and the rest of the set. Now in some rare occasions the driver transistor for the relay was shorted But most of the time its the contacts that weild shut, but you cant just clean them as it will work for a while, but in a month or so you will be in the smame boat. But if you not a tech this repair shouldnt cost you to much because if your not an experienced tech you can not only cause harn to the set but also you yourself BE CAREFULL and take the set to a pro!!!! Good Luck
Posted on Jul 27, 2006
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
I have a phillips 60pp9100d that has no picture or sound. I keeps flashing I2c bus error. I have resoldered the flyback connections and anything else that looked suspect. After turning the tv back on I get...
You need to rectify the problem first then replace any part. If you have its service manual, try to daignose the reson of error and locate the problem area.
Jul 23, 2008 | Televison & Video
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Help fix error code sc690 on ricoh 2035 copier
SC690 - A GAVD block I2C bus error.
An error is detected in the GAVD communication I2C control register of the GABIC2.
• I2C bus on BICU defective.GAVD IS THE laser controller loacated on the laser unit.
Nov 01, 2011 | Ricoh Aficio 2035 Copier
Power on for a few seconds then turn off
Tv is going into x-ray protection mode. Check power supply voltage, make sure it's not too high. 160v dc across main cap, do not use chassis ground, use cap ground. If too high, something is open. If too low, something is shorted in power supply. Check voltage regulator ic.
Oct 05, 2011 | JVC AV-32D305 32" TV
Sc 690 ricoh aficio 1035
the GABIC2.
But I had this problem with LD Unit and Flat Cable broken. try to locate a loosen Flat cable to the LD unit.
Aug 26, 2011 | Ricoh Aficio 450 Copier
Closed caption
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Just word search the manual for closed caption
if you can find this in your TV options I cut and pasted it from the manual, see the line with Closed caption settings see if yours matches, sorry about the formatting this furm post will not cut and paste properlyeach of the #'s below corosponds to the bold headings.
OptionSetting/Basic2US1/BasicW/Basic+2US2/Core2US3/Basic+2US4
AAVL 1 1 1 1 1 Auto Volume Level via Sound Menu
ACS 0 0 0 1 0 Auto Convergence
AOUT 1 1 1 1 1 Audio Out
APC 1 1 1 1 1 Auto Picture Control
AV3 1 1 1 1 1 Side AV Source
AV5 0 1 1 1 1 (yes this is blank)
BNUM 1 1 1 1 1 Numerics Displayed in Menus
C169 1 1 NA 0 NA Compress 16:9 mode available
CBFL 1 1 1 1 1 Comb Filter Present
CCAP 1 1 1 1 1 Closed Caption
CFMU NA NA 1 1 1 Comb Filter Menu Item
I also found this with the word search but it makes no sense to me sorry...
The HDR2002 has two microprocessors. The Microprocessor, 7001, on the SSB monitors the Keyboard and the Remote sensor during standby. This IC controls the Tuner, Video switching on the SSB, generates the consumer OSD. Pin 5 of 7001 monitors the Keyboard for a voltage change to generate a command. The Front Detect line on Pin 6 monitors the AV inputs on the Side Jack panel. If a problem develops, the Front Detect will go Low, preventing 7001 from receiving any commands. The Power Fail input on Pin 79 goes High if the set looses power while the set is On. Composite Video is fed to Pin 31 for Closed Caption decoding. Horizontal and Vertical sync on Pins 53 and 55 synchronize the OSD and Closed Captions display signals, which are output on Pins 46, 47, and 48. Fast Blanking for the OSD is output on Pin 52 There are three I2C busses on 7001. The Bus on Pins 78, 80, and 97 communicates with the MemoryIC 7012. This IC stores Customer setup information, Option codes, and Error codes. I2C busses, Sand F communicate with the Tuner on the PIP panel, and the ICs on the SSB. The S bus also controlsthe Tuner on the SSM and the Audio and Video switching on the SSM. Data lines on Pins 16 and 17communicate with the Microprocessor on the ACS module.
below is my general post about this TV, I'm not sure if any of its info will help but there are links to other info on this TV set... Good luck
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 06, 2008 | Philips Magnavox 51MP392H Rear Projection...
JVC AV-27D304 display
hit the display button on your remote should turn it off
Apr 08, 2008 | JVC AV-27D201 27" TV
POWER WON'T TURN ON . YES, POWER SUPPLY OUTLET IS GOOD
Replace capacitor C926 near center of circuit board chassis (label is on the bottom) by a 1000uF 50V. Mind the polarity!
R,
A
Feb 05, 2008 | JVC AV-35750 35" TV
WON'T TURN ON. POWER SUPPLY GOOD
Replace capacitor C926 near center of circuit board chassis (label is on bottom) by a 1000uF 50V one. Mind the polarity!
R,
A
JVC AV-32260 32" TV Logo
373 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
