Question about Epson Stylus Photo R300 InkJet Printer
PRINTER sick swallowed too much paper at one go.can you help
Hi
The paper jammed in the printer i got it out but now it wont print from the laptop but it prints perfectly from a memory card.What could be the problem, is it fixable or should i give it a decent buriel......
Thanks for any help you can give.
Teresa K
  • bishbosh42 Nov 08, 2008
    I have the same problem, exactly as described above. The printer sucked too much paper through which jammed. I took the paper out without any ripping, but the printer now won't operate and says 'general error'. Any suggestions anyone?
  • Epson Master
  • 541 Answers
You need to reset the printer let me no if you dont have the software
Posted on Nov 18, 2008
Can't print pictures from my laptop. The printer always says paper jam but there isn't one
"Paper Jam" issues are common with printers. They most often occur right after there has been a paper jam. Most people (not necessarily YOU), don't take the time to read how to properly clear a paper jam in their printers and often yank the jammed sheets backward thru the paper tray. Most times you should remove the cover in the back and pull the jam FORWARD out the rear, or if the jam made it close to the output tray, then FORWARD thru to the output tray. Pull sheets backward can cause two issues. It makes tearing the paper easier. This can result in tiny pieces being caught in places where the printer detect them as a jam. The other issue is that pulling backward can damage the feed rollers that pull the paper into the machine, as well as the mechanical sensors that detect paper jams. If you cannot find ANY shards of paper in the machine, you may have printer damage that results in the jam indication.
Oct 10, 2015 | HP Computers & Internet
Hi, My printer will not feed-in the paper and will not print, also the laptop is not asking printer to print
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
The printer is jammed and i can get it out....thus
Using your printer's manual or by accessing online support, seek the way to open the panel to access the paper stuck in the printer. Gently, take the sheet out and the printer will work as good as before. Hope this helps.
Aug 22, 2009 | Brother HL 2140 Laser Printer
Printer wont scan
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 21, 2009 | Lexmark X2500 All-In-One Printer
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Paper jam wont print
hi dear
you have an old printer, but still oke, take care, to open the back panel from your printer
pull the jamming paper, and make it clear with self test
oke
Apr 06, 2008 | HP DeskJet 640c InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
29 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
