Question about HP Office Equipment & Supplies
When making copy from computer I keep getting prints of material copied last week from scans. I tried everything recommended but no luck.
  • rosa1 Oct 21, 2008
    S/N CN5ABC139604BM PSC1400 series
  • rosa1 Oct 22, 2008
    I was asked for code nbr for printer which I furnished. Haven't recd any solution for the problem yet, though.
    Genius:
  • 1,550 Answers
You need to reset your printer .
Unplug your printer for 30 minutes and plug your printer .
This will erase the previous data .
Posted on Oct 21, 2008
  • HP Master
  • 6,487 Answers
Can you please provide us first the model of the printer so we can help you better...
I'm unable to get the scanning and copy output on samsung series
turn on/off, unplug, plug in2_bing.gif, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer/scanner/copy. check settings. if all else fails, select printer reset button in settings page.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Samsung CLX 3160fn All-In-One Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
I can't print scanned material to full size.
You can try the freeware at the link below:
http://www.bestsoftware4download.com/software/t-free-freekapture-download-npbskbaz.html
The description states: "You can also use FreeKapture as an 'ad hoc' copy machine (by using your printer drivers 'how many copies to print' option)."
It works with all twain compliant scanners. Download and install and then point it to your scanner.
Good luck, and please let me know how it works out for you.
Mar 19, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
My Lexmark X75 will print but not copy. When I
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print. Are you copying from the button on the X75 or from the All-In-One Center software on the computer? If the button, try it from the software.
Feb 24, 2009 | Lexmark X75 All-In-One InkJet Printer
Print
Hi
Try to uninstall and reinstall driver. and make sure when you are printing from computer the printer is set to copy mode.
Hope this helps
Sep 06, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Cannot access scan function
Hi , did you try a manual copy thru the printer operator panel to make sure that there are no issues with the hardware , if it is copying manually then its an issue with the software , you need to uninstall the printer drivers through the Printer Disk ****make sure to disconnect the printer cable from the computer before uninstalling the drivers **** once the printer drivers are uninstalled restart the computer and get into the Safemode (**keep tabbing F8 when the system restarts for safemode**) and delete the following Folder " SPOOL " it is located under C:\WINDOWS\system32. after deleting the Spool folder restart the computer and install a fresh copy of drivers it will resolve your issue.
Do let me know once you perfrom these steps.
All the Best.
Jul 10, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark 8300 print/scan/fax
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Jun 19, 2008 | Lexmark X8350 All-In-One InkJet Printer
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
Ben Johnson
