Question about HP PSC 1610 All-In-One InkJet Printer
Printing on both sides
I have an HP 1610v all in one.  I used to be able to have the "print on both sides option" when I used a PC.  Now I have a macbook, and the "print on both option" is on the menu, but does not give me the option to choose it.  I've repeatedly try to update drivers to no avail.  Frustrated!
Any advice would be greatly appreciated.
Thanks!
    Scholar:
  • 78 Answers
Check the printer setup and configuration to make sure the duplex option shows up as installed. If not, install / add the option from the option list, and this should return the duplex option to availability. If it doesn't show up in the option list, then the computer is not recognizing it as being installed in the printer, and we will have to look further as to why.
Posted on Nov 19, 2008
HP Officejet 4315 All-in-one I am a Mac user and I cannot do duplex printing or two sided printing
Mac uses a generic driver for all printers. have you verified that duplex printing is check under the printer options?
System Prefs -> Print & Fax -> select the printer, Options and supplies -> driver.
NOTE: if it says print using "Generic postscript driver" you will need to install the manufacturer driver for the printer to get the option to turn on the duplex printing.
May 23, 2011 | HP OfficeJet 4315 All-In-One InkJet...
I cant stop my printer printing both sides of the paper
After you attach the two-sided printing accessory (duplexer) to your product, you do not have the option to print on both sides of the paper when you try to print. The two-sided printing option is not available in the print dialog box.
NOTE: The HP Automatic Two-sided Printing Accessory (Duplexer) ships with some printer models and is available as an optional accessory for others. Solution First, choose your operating system. Next, follow the steps to make sure that your printer driver recognizes the duplexer. Show all ' Hide all hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows XP Follow these steps to make sure that your printer driver recognizes the duplexer. Step one: Add the Duplex Unit to your printer settings
  1. Click Start , click Control Panel , and then click Printers and Faxes .
  2. Right-click the printer icon (c01601478.gif ) for your HP product.
  3. Click Properties , and then click the Device Settings tab.
  4. Click the plus sign (+ ) next to Installable Options to expand the list.
  5. Click Duplex Unit (for two-sided printing) , and then select Installed from the drop-down list.
  6. Click Apply , and then click OK .
Step two: Set the Two-sided printing preference
  3. Click Printing Preferences , and then click the Features tab.
  4. In the Paper Saving Options area, select Automatic from the Two-sided printing drop-down list.
  5. Adjust other print settings as needed.
  6. Click OK to save the settings.
hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows Vista Follow these steps to make sure that your printer driver recognizes the duplexer. Step one: Add the Duplex Unit to your printer settings
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), and then click Printers .
  6. Click OK to save your settings.
hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows 7
Oct 31, 2010 | HP Photosmart Premium C309g multifunction...
Does the hp psc 750 do double sided printing
I have not used that specific printer, but from all I can determine, it is not a duplex printer. However hp offers these suggestions on how to determing if your printer is duplex: <br /> "To find out if your printer supports duplex printing, refer to your printer manual or look for the <b>Two-sided (Duplex printing)</b> or <b>Print on both sides</b> drop-down menu in the <b>Printer Properties</b> dialog box on your PC (sometimes found in the <b>Printer Shortcuts</b> tab).<br /> If you can
Aug 20, 2010 | HP PSC 750 All-In-One InkJet Printer
Option to Print on both sides does not appear
Check your driver. If you are using a recent version of "HP Universal Printing PS" driver, the duplex option is in the finishing tab.
Feb 10, 2009 | HP LaserJet 4650 Color Printer Manual...
How do i run a leaning cycle on hp psc 1610 all in one printer?
go to printer properties in your pc.
for going to printer properties just give the printout from the file and on that page on the right upper corner u can see properties.
then click that properties.
in that printer properties there will be option.in that ---service option----or utility option-----or maintenence option----or printing preferences option----in any of the above option there is a option given clean the ink head just click that option and continue.
Nov 01, 2008 | HP PSC 1610v All-in-One Printer
Not printing with all colors
tw options can be done for this
1)get the same colour cartridge refilled
2)or buy a new cartridge.
simple.
as the cartridge is over.u have this two options only
Aug 10, 2008 | HP PSC 1610v All-in-One Printer
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
HP laserjet 5000 series PCL 6 driver
have you tried from the print command dialog box from pc
Apr 28, 2008 | HP LaserJet 5000dn Printer
Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
Aug 18, 2007 | HP Photosmart 3310 Printer
HP PSC 1610 All-In-One InkJet Printer Logo
Ben Johnson
