Samsung HP-T4254 42 in. Plasma Television
Problem for Samsung HP-T4254 42 in. Plasma Television
Samsung 42" Plasma HPT4254
By nancynancy on Oct 21, 2008
TV turns off by itself and makes a clicking sound. Only way to turn it off is to unplug the unit.
Same Problem
May 17, 2009
-   T.V. turns on and off by itself. Makes clicking wound while it's doing it. Have had T.V. for under 2 years. -   Guest
Apr 07, 2009
-   When i turn on my tv it come on for about three minutes then shuts off making a clicking sound, the same sound it makes when you turn it on or off. -   pikfiredawg3
Feb 27, 2009
-   My HP-T4254 started turning on and off by itself for a few days but now it won't turn on at all. It's only 19 months old and out of warranty range - Samsung referred me to an authorized repair store and they said it sounds like something on the board - minimum $500 repair if not more. If I wait a little while I can buy a new one for the same or near price. I thought Samsung was quality - I guess I was wrong!-   danielblue
Feb 19, 2009
-   I've had the Samsung PN50a450 for less than 30 days and it cuts on and off by itself. It's plugged into a Moster power surge protector.
At first it cut off every hour, then it was every 30 min. Now it's intermittent. It shuts down, clicking sound is heard, then it will cut on by itself. At first I thought it had something to do with the misc. remote controls (infra red signals crossing). After covering up the remotes, the tv went a week without cutting off. Then it started all over again. Have no clue!!! Somebody help. Samsung came out and had no clue what was going on. They didn't even come equipt with tools to test the tv! Any ideas????? email me wyrick@prodigy.net-   wyrick
Jan 23, 2009
-   Same problem on T4354: click on and off. Firmware upgade DID NOT help.-   rfloyd71
Solution #1
posted on Nov 11, 2008
Somewhat Helpful)
solutiondoct
Rank: Wiz
Rating: 77%, 46 votes
You need to either call Samsung if it is under warranty or get a TV repair guy for you.It is a common defective problem i have seemed from Samsung,but usually it happened within the firs 30 days.
solutiondoct
Was this helpful?
Yes
No
Solution #2
posted on Oct 05, 2009
Not Rated)
osvaldocapet
Rank: Apprentice
Rating: 0%, 0 votes
i have the same exact tv with the same problem... it was a bad connection on a transistor... look at the connections closely
osvaldocapetillo@yahoo.com
Was this helpful?
Yes
No
Solution #3
posted on Mar 04, 2009
Not Rated)
da13thninja
Rank: Apprentice
Rating: 0%, 0 votes
EITORRES,
I have a question for you? what was the process like to replace tthe power supply. my tv is out of warranty so am thinking aboutdoing it myself. i saw the power supply unit on ebay for 100 bucks plus shipping.
Was this helpful?
Yes
No
Solution #4
posted on Mar 01, 2009
Not Rated)
eitorres
Rank: Apprentice
Rating: 0%, 0 votes
THE ONLY SOLUTION I FOUND WAS TO CHANGE THE POWER SUPPLY CARD INSIDE. WHICH IS NOT DIFICULT AT ALL
Comments:
Apr 02, 2009
- THIS IS FOR DA13THNINJA :
IT WAS EASY... JUST OPENING IT WAS REMOVING ALL THE SCREWS AND A COUPLE OF TINY NUTS (FROM THE CPU INPUTS) THEN TE REST IS UNPLUGING AND UNSCREWING SOME MORE AND REMOVING THE CARD AND REPLACING IT WITH THE NEW ONE. IT WAS VERY SIMPLE
Was this helpful?
Yes
No
Popular Solutions for Samsung HP-T4254 42 in. Plasma
Questions and Unsolved Problems for Samsung HP-T4254 42 in. Plasma
Do you recommend Samsung HP-T4254 42 in. Plasma Television?
Answer
Answer
i have a hp t 4254. it randomly turns itself off and back on.
Answer
my tv is making a tweaking noise every minute or two
Answer
Have HP-T4254 that turns on and off continuously. Yesterday, I REPLACED the main power board on the... (More)
Answer
There is no picture or volume after we unplugged it for a while. The Logo lights up, but that's all.
Answer
when the power button is pressed the tv doesn't turn on
10 Other Users Have The Same Problem - Continued
Comment by caybar, posted on Jan 07, 2009
The problem just began today. The TV is only 15 months old. It was on for a few minutes when it suddenly turned off and began making clicking sound. Nothing appears to be solving the problem. We've tried unplugging it, but no go.
Comment by stfraw, posted on Jan 07, 2009
Exactly same problem here. My plasma is like 18 monts. Now, it doesn't even turn on, just clicking... Please post (or e-mail me @ stfraw@yahoo.com) what was the solution for you. Thanks.
Comment by Guest, posted on Dec 03, 2008
it was the same problem with our samsung HP-T4254 42 in. plasma tv. it will turn on and after a minute it will turn off and make a clicking sound. the only way to stop the sound is by unplugging it. it was just 14 mos. old unfortunatley it was out of warranty and samsung company cannot do anything about it . they told us that they can give 30 days extension warranty by registerig at samsung website we did that and after a few days we called up and told us we need to fax the receipt, and then a a few days nothing happened, we called up again for the follow up and told us that the extension that they gave us in not valid and so we end up being referred to a repair service who is charging us a non refundable $90 just for the check up and up to us if we are going to have it repair or not.they said that the service fee and reapir will cost us a little expensive. ( the parts to be replace, availability etc.)
Comment by mrjkamau, posted on Nov 18, 2008
Mine used to do that, now it wont turn back on even if I unplug it unless I wait for hours.
Comment by eitorres, posted on Nov 09, 2008
What extra information do you need to help solve this issue.. I have the same problem.
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
