Question about GE DBSR453EBWW Electric Dryer
Removing motor from blower
How do you remove the blower assembly from the motor ? Pully looks like it's been pressed on at manufacturer.
  • 62 Answers
You are correct, we just automatically replace the blower wheel, and screw on the new one. You have to chisel the old one off, most of the time, to get it through the hole.
Posted on Oct 22, 2008
How do I get the old motor off to replace it if it is stuck
Remove the front blower cover assembly. Remove the round retaining clip on center of blower wheel. Pull blower wheel off motor shaft. Remove belt from motor pully. Pull out dryer drum. Remove clips holding motor to base frame. Remove motor assy. Easy peezy. Reassemble in the opposite manner.
Jun 21, 2014 | Whirlpool LEN2000PW Dryer
Heater switch replacment
Hello! it's my job to make things as easy for the customer as possible...Therefore I must ask why you want to replace the heater switch? Is it because you have lost one or two of the switch speeds? Your vehicle is noted for loss of the Blower Motor Resistor...
Changing the Heater switch means removal of the Climate Control Assembly which is not the easiest of jobs...I've included the process...But are you sure the blower resistor is OK? If you have lost 1,2, or all blower motor speeds it's more than likely the Resistor pack. And a lot easier to change...
Guru...saailer
Remove climate control:
  1. Remove the instrument cluster finish panel...
  1. Remove the 3 climate control assembly screws...
  1. Disconnect the climate control assembly vacuum connector...
  1. Disconnect the 5 climate control assembly electrical connectors...
  1. Remove the climate control assembly..
Removal of blower motor Switch:
  1. Remove the blower motor switch knob.
  1. Remove the blower motor switch.
    1. Remove the screw.
Removal of blower motor Resistor:
Blower Resistor is under the battery tray...
MOTORCRAFT Part # YH1698 ...cost $25
Guru...saailer
Dec 22, 2011 | 2007 Ford Econoline
How do I replace the heating fan on my 2000 Kia sportage
Blower Motor
Removal & Installation
To Remove:
  1. Evacuate and recover air conditioning refrigerant.
  2. Remove battery.
  3. Disconnect and cap A/C lines at evaporator tubes.
  4. Remove blower motor assembly drain.
  5. Remove glove box.
  6. Remove 5 screws and right hand instrument panel lower trim panel.
  7. Remove screw that attaches upper center console to gain access to left
    instrument panel lower support.
  8. Remove left and right bolt and remove instrument panel lower support.
  9. Detach control cable from inlet duct.
  10. Disconnect blower motor electrical connector.
  11. Pull carpet back and remove hole cover plate.
  12. Remove 2 bolts at top of blower motor assembly.
  13. Remove 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  14. Remove blower motor assembly.
To Install:
  1. Install blower motor assembly.
  2. Install 2 bolts at top of blower motor assembly.
  3. Install 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  4. Install hole cover plate and replace carpet.
  5. Connect blower motor electrical connector.
  6. Install instrument panel lower support and install left and right bolts.
  7. Install right hand instrument panel lower trim panel and 5 screws.
  8. Install glove box.
  9. Install blower motor assembly drain hose.
  10. Connect evaporator lines at bulkhead.
  11. Evacuate and charge air conditioning refrigerant.
  12. Install battery.
Oct 29, 2010 | 2000 Kia Sportage
How to replace a blower motor in a 1996 ford thunderbird lx
Removal
  1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
  1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
  1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
Installation
  1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
  1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
  1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
  1. Install the glove compartment liner.
Oct 07, 2010 | 1996 Ford Thunderbird LX
Where is the a/c blower motor located on my 1997 pontiac sunfire?
prev.gif next.gif HEATING AND AIR CONDITIONING Blower Motor REMOVAL & INSTALLATION Fig. 1: Remove the sound insulator from underneath the passenger side of the instrument panel 91146p69.jpg
Fig. 2: Remove the retaining bolts for the blower motor assembly 91146p61.jpg
The blower motor and fan are serviced as an assembly only.
  1. Disconnect the negative battery cable.
  2. Remove the passenger side sound insulator.
  3. Detach the electrical connections from the blower motor.
  4. Remove the blower motor retaining screws, then remove blower motor and fan assembly. To install:
  5. Install blower motor and fan assembly, then secure using the retaining screws.
  6. If equipped, connect the blower motor cooling tube.
  7. Attach the electrical connections to the blower motor.
  8. Install the right side sound insulator.
  9. Connect the negative battery cable.
Aug 03, 2010 | 1997 Pontiac Sunfire
1999 caviler blower
GM Cavalier/Sunfire 1995-2000 Repair Guide
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
To install:
  1. Install blower motor and fan assembly, then secure using the retaining screws.
  2. If equipped, connect the blower motor cooling tube.
  3. Attach the electrical connections to the blower motor.
  4. Install the right side sound insulator.
  5. Connect the negative battery cable.
Good luck (remember rated this).
Jun 22, 2010 | 1999 Chevrolet Cavalier
How to install a front blower motor in a 96 ford explorer
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
I need to replace the heater a/c blower motor, how do I.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from remote negative terminal on shock tower and properly isolate to prevent accidental reconnection.
  3. Remove or disconnect the following:
    • Glove box assembly
    • Joint duct
    • Resistor
    • Blower fan and motor
    • Air changeover damper motor
    • Blower assembly
To install:
  1. Install or connect the following:
    • Blower assembly into duct
    • Air changeover damper motor and reconnect the electrical plug
    NOTE Lubricate the damper motor's slide contacts with multi-purpose grease
    • Blower fan and motor into the plenum and reconnect the electrical plug
    • Resistor on the joint duct
    • Joint duct to blower assembly
The blower motor is located on the right side of the heater housing.
  1. Disconnect battery.
  2. Remove the lower right under panel silencer duct.
  3. Remove the blower motor connector from resistor block.
  4. Remove the blower motor case retaining screws.
  5. Lower blower motor case from housing
  6. Remove the fan scroll from motor shaft.
  7. Remove the motor from motor case.
Blower motor (1)
To install:
  1. Install the in reverse order of removal.
Jan 19, 2010 | 2000 Dodge Stratus
Tensioner assembly.
the assembly you are looking for is on the passenger side of the motor there are some bolts you need to remove and it is alot easier if you remove the powersteering pump once you have the tension assembly off the car you will need a torkx bit to remove the pully. I just couldnt see myself spending 800.00 so i called the local auto parts store and they ordered the tension pully it caos me 26.00 but it was a long 10 hrs (there were other things I was fixing also
Jul 08, 2009 | 2001 Plymouth Neon
Air and heat wont work unless blower is on high, where do i find the regulator to change it
Sound like the blower motor resistor is bad.
Blower Motor Control Module Removal & Installation To Remove:
  1. Remove the insulator from the right side of the instrument panel.
  2. Disconnect the connectors from the blower motor resistor and blower motor.
  3. Loosen the two forward screws and remove the rear screw of the resistor assembly.
  4. Remove the blower motor resistor assembly.
To Install:
  1. Install the blower motor resistor assembly.
  2. Install the rear screw and tighten the forward screws.
  3. Connect the electrical connectors to the blower motor and resistor assembly.
  4. Install the insulator under the right side of the instrument panel.
Jun 24, 2009 | 1998 Buick Century
GE DBSR453EBWW Electric Dryer Logo
51 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
