Question about Refrigerators
Kenmore Elite side by side refrigerator freezer
We are planning an extended leave from our home. My question is this; can I safely unplug this appliance while we are away (cleaning it out of course). I've heard on older products that you should leave them running. In this case we may be away as long as five months. I plan to unplug all our other appliances during this absence. Will my refrigerator/freezer be ok when we plug it back in. We bought this refrigerator brand new and it is only about 19 months old.
Thank you.
Carmen
  • 958 Answers
If you will be affected by freezing weather, it is advisable to drain all water from your reservoir to prevent from freezing and can damage the plastic tank.
if not, then it is safe just to unplug it and leave it. clean.
tnx 4 using fixya,
drcool
Posted on Oct 21, 2008
Kenmore Model 10654613300 Freezer over freezing
In the freezer side there is a panel in the back. behind the panel are the evaporators. over the evaporators are heaters you will find one of then broken from water dropping on it the bottom one was broken on mine. put a fan to the freezer and thaw it out. get the model and serial numbers and look on ebay.com. or there is a place called http://www.repairclinic.com/
These are not hard to change but above all UNPLUG THE FRIG OR THEY MAY PUT YOU IN ONE.
Hope this helps.
Sep 21, 2014 | Kenmore Elite Side By Side Refrigerator -...
I unplug the Kenmore elite not working after unplug
um engine? not sure there is an "engine" on it but there are 3 things that make noise 2 fans and the compressor. Are all three running
Jul 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We just replaced the water filter...now dispenser doesn't work.
Looks like water is frozen in the tank .Unplug refrige from wall socket ,leave freezer and food compartment doors open at least 12 hours to melt frozen tank..
Jan 18, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a kenmore elite refrigerator. Am trying to
plan on 11 amps which would be 1100 watts and 115 volts.
Oct 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite freezer/fridge hot to the touch on the front.
I recommending unplugging the fridge, taking off the back panel, and at looking in there. I was having the same symptoms, overheating panel between the doors on our side by side. Ends up that a mouse was stuck in the fan and stalled it out. Fortunately (at least so far), once I removed the mouse and plugged back in, the fan started back up.
Jun 25, 2009 | Kenmore 63893 Stainless Steel Top Freezer...
Kenmore Elite Side by Side refrigerator not cooling enough
it could be either gas problem or may be compressor is not working
May 14, 2009 | GE GSS20IEP Side by Side Refrigerator
Control pad is flashing and can't seem to reset tempeature
try unplugging the unit and waiting 9 minutes then plugging it back in.
Dec 26, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
