Canon MultiPASS F60 All-In-One InkJet Printer
Problem for Canon MultiPASS F60 All-In-One InkJet Printer
PROBLEM COPYING WITH MY ALL- IN- ONE
By cakelady on Jul 26, 2006
ERROR MESSAGE READS "WASTE INK TANK NEARLY FULL" IS IT POSSIBLE TO FIX THIS MYSELF OR DO I HAVE TO SEND IT IN FOR REPAIR?
Same Problem
Feb 06, 2009
-   I need to know how to empty the overflow tank?
ivanwil@frontiernet.net-   ivanwil
Nov 13, 2008
-   ip 1000 provide this message that  wate absorver is full contac.......... -   ashiq_rahman
May 07, 2008
-   Yes same problem Canon MP170 check printer & 5B00 only step I have taken is called my service centre and they suggested I purchase new printer do you know of a trick to help me out.-   Guest
Apr 08, 2008
-   Hi. I have a Pixma MP170 and have the same problem - 'Waste Full' message on screen and flashing '5800' on printer. I've unplugged it - but no joy.
I've looked through your list of 'Reset' methods, However my printer does not seem to have a reset button!!! So now I've got no idea what to do. Please help!-   jjeejj
Apr 02, 2008
-   pls. send adjustment software to reset waste ink counter for canon bjc-2100 inkjet printer. i did manually but i didn't work. the problem still remain.-   bubka
Best Solution
posted on Jun 25, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you!! Very helpful...I seem to have solved my MPC 190 problem 'Waste Ink Tank Nearly Full'
Only Difficulty I had was finding 'Set' Button
geoff gnbishop@bigpond.com
Solution #2
posted on Jul 26, 2006
Helpful)
NeoOne
Rank: Guide
Rating: 82%, 102 votes
This message is inbuilt into most Canon printers, there is spongy thing in the printer which when fills up fires the message (it's mostly a counter in the printer, which can be reset more later...), per Canon this can only be dealt with in a lab but some of the more adventurous have tried cleaning it by themselves.
Note that in a lab they won't clean it, it's a part that needs replacing and it might cost around $60.
In most Canon printers there is a reset procedure that can reset the error and allow you to print some more before handling it again.
Following are the reset procedures for some of the Printers:
(not that F60 isn't listed here)
Canon GENERIC "S" SERIES RESET CODE
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Canon PIXMA iP1000
Waste Ink Counter Reset Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
Canon PIXMA iP1500
Waste Ink Counter Reset. Manual for Service mode
should be orange.
Canon i320, i255
Step 1 : Manual Temporary
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or Step 1: Manual Temporary
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Canon S450 Printer
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5. Release Power button
6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
7: Press Power to set data
Canon BJC 1000 Serie
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Canon BJC-2000 BJC-2100 Serie
1: Remove the Cartridge
3: Close Front access panel
3: Hold down the RESUME/RESET button and plug in the AC power cord
4: Release RESUME/RESET after plugging in the AC Power cord.
5: Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET .
6: Press and HOLD RESUME/RESET for two seconds or more and release it.
7: Press and HOLD RESUME/RESET for two seconds or more and release it.
Canon BJC-210 BJC-240 BJC-250 BJC-255 BJC-265
Canon BJC-4100 BJC-4200 BJC-4300 BJC-4400 BJC-4550 BJC-4650
Unplug Power Cord
Hold POWER and RESUME buttons
Plug in Power Cord
Release buttons
Open front door of printer
Hold the CARTRIDGE and RESUME buttons
Press POWER
Release all buttons after the beeps
Press CARTRIDGE once
Press RESUME
Canon BJC-5000
2: Press and hold RESUME then press POWER, The indicator will start blinking.
3: While the indicator is blinking , Press RESUME twice then Wait until the printer beeps to indicate service mode
5: When the indicator lights steady GREEN, press RESUME four(4)times. The indicator should be GREEN.
6: Press Power to set data
Service Test Print
5: When the indicator lights steady GREEN, press RESUME two(2)times. The indicator should be GREEN.
6: Press Power to Print
Nozzle Print
2: Press and POWER, until the printer beeps and release.
Demonstration Print
1: While the printer in ON , , Press and hold RESUME until the printer plays a melody of beeps.
Canon BJC-5100
Self Test
Switch Printer off. Hold Power for 1 beep.
Waste Counter Reset
Service Test Print
Nozzle Print
Demonstration Print
Canon BJC-3000 BJC-6000 BJC-6100 BJC-6200 S400 S450 F300 F600 F620
Canon BJC-7000 BJC-7100 BJC-8000 BJ-F800 i6500
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
Canon BJC-600 BJC-600e BJC-610 BJC-620
1: Unplug Power Cord
2: Hold POWER and FF and Print Mode buttons
3: Plug in Power Cord
4: Release after the beeps
Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70
2: Hold POWER and RESUME buttons
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Canon BJ-30 BJC-35v BJC-70
F14 Error Reset
1: Unplug adapter
2: Hold POWER
3: Plug in ADAPTER
4: Release POWER after printer starts
5: Hold FF and MENU and press POWER
6: Release after beeps
7: Press <> Cartridge until 1A is displayed
8: Press ONLINE
9: Press POWER to shutoff printer
10: Unplug printer then re-plug printer
Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
You are now in Service mode.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a resta
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA IP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Canon S900, S820, S750, S520
While still holding the POWER button, Release the RESUME button, then press and release the RESUME button two more times in succession.
The printer mechanics will move momentarily. You are now in Service mode. Release the Power Button.
1. Service/factory test printout, including ink sensor check
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
Canon S9000
Turn off printer
Canon MPC190
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing Menu Copy Scan Copy Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Mar 27, 2008
Helpful)
landwolfe
Rank: Apprentice
Rating: 84%, 4 votes
Here's the most detailed SOLUTION for resetting the WASTE INK COUNTER in a CANON BJC-55:
Waste Error Reset
Many thanks to Vince Gyver for sending this in.
  1. Unplug Power Cord
  2. Remove the Battery
  3. While pressing and holding the RESUME Button plug in Power Cord
  4. After two seconds press the POWER Button
  5. Release Buttons immediately (as soon as the led light)
  6. Press and hold CARTRIDGE, RESUME and POWER Buttons
  7. Release all Buttons after the beeps (POWER LED will be off, Charger LED will light orange)
  8. Press CARTRIDGE 16 times (POWER LED and Charger LED will light alternately after each press)
  9. Press RESUME (Printer will automatically power off)
  10. Put Battery back in the tray
  11. Power On and have fun with your Printer (Don't forget to replace or clean the Waste Tank Pad!!!)
Guest (from: http://www.xn--blckpatrondirekt-wnb.se/canon.asp?id=BJC+55)
Was this helpful?
Yes
No
Solution #4
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have 5 printers of different makes and this has never been a problem with any of the others. May I suggest that you warn all prospective buyers of Canon Printers of this problem. I was never warned this could happen.
Popular Solutions for Canon MultiPASS F60 All-In-One
Questions and Unsolved Problems for Canon MultiPASS F60 All-In-One
Do you recommend Canon MultiPASS F60 All-In-One InkJet Printer?
Answer
Answer
My canon F60 multipass alarm light is blinking, says to check printer and press resume key. Does not... (More)
Answer
error 6000 keeps coming up,how can I fix it? It wont let me print
Answer
I just replaced ink and pressed resume. the printer is not doing anything and the alarm light is... (More)
Answer
i cannot connect with my cannon multipass f60
Answer
i cannot connect to my cannon multipass f60
8 Other Users Have The Same Problem - Continued
Comment by bubka, posted on Apr 02, 2008
i did waste ink counter reset by manual method. but the problem still remain. pls. send any adjustment software to reset waste ink counter
Comment by Guest, posted on Mar 12, 2008
Success. fixyourownprinter.com/forum/inkjet/29693 tells you how to reset your printer after cleaning the waste ink tank. It worked on my SmartBase MP360.
Comment by cap262, posted on Dec 31, 2007
My MultiPass F60 will not print. Reset button does not reset.
Error message: wasre ink tank near full. Tried fix options to reset, no luck.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon MultiPASS F60 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
