Question about Refrigerators
I have new fridge by kenmor( Sears) by side doors. Freezer is ok but the fridge (right side or the fridge) side is not cooling. There is no air blowing through the openings in the cooling side.The fen and compressor are working. Looks like something is bloking the air to go from freezer side to fridge. Please help.
  • 958 Answers
Check if there are still packing tapes holding the flap of the opening. these dampers could also be stuck closed.
but the best thing to do is wait for the tech from sears, since it is brand new. it is still under warranty.
tnx 4 using fixya,
drcool
Posted on Oct 21, 2008
Kenmore refrigerator, freezer cooling but not fridge
check door that allows freezer air into fridge side might be stuck closed or blocked by food. located upper left and corner of fridge side
Aug 31, 2014 | Kenmore Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Fridge not cooling enough, freezer cold but not freezing
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Aug 31, 2011 | Kenmore Side by Side Refrigerator
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
The refrigerator door was left ajar for several hours. then the ref cooling system was not functioning right after the incident. although the freezer is still doing its job Im worried if its beyond repair....
When the freezer section gets cold and reaches its required cooling temperature,after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge.But if the defrost cycle does not start then freezer will block the air passing section from freezer to fridge,so the freezer gets cool but fridge section does not cool. Its the defrost problem.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check,if the same problem is noticed again,.If yes then its defrost board problem.The defrost board located in the back of fridge section.You can get required parts from www.repairclinic.com or from online sears part site.------------- Thank you.
Jan 31, 2011 | LG LSC26905TT Side by Side Refrigerator
My freezer cools properly but my refrigerator is not staying cool .its kenmore and bought from sears 2004 $1000. side by side refrigerator
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace this part for a permanent fix - also advisable to swap out the defrost timer at same time
Aug 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
