Spin cycle not working
  • spin cycle not spinning every thing else works.
  • brandi292000 May 02, 2009
    MY WASHING MACHINE IS OLD BUT HAS ALWAYS WORKED JUST FINE. NOW ALL OF THE SUDDEN THE SPIN CYCLE IS NOT WORKING. HOW CAN I FIX THIS PROBLEM BEFORE SHOPPING FOR A NEW MACHINE?
  • 958 Answers
Please check your lid switch or door switch.
tnx 4 using fixya,
drcool
Posted on Oct 21, 2008
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
Spin cycle will not work on siemens xlm 1400 and filter has been cleaned what to do
If the spin cycle is not working, it could be several things. How is it not working? If it won't do anything, i.e. doesn't turn, then I would suspect the transmission since the spin cycle is the high side of the transmission. If it spins but does not take the water out of the unit, then I would suspect, either the pump or the timer.
Good luck and have a great day!
Jun 09, 2011 | Washing Machines
Will not spin or aggitate. giving a code of some sort
look under the door. there is a switch that will not allow the spin cycle to work if the door is open - like when you open the washer door on the spin cycle and the spin cycle shuts off until you close the door again, its a safety thing.
see if the switch works.
cost around $3.00 put in with a screw driver - good luck - aloha
Feb 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
No spin cycle
check the lid switch,if they go open it will not spin due to safety reasons, you can bypass this switch for testing the spin cycle,then if things work,just replace this switch
Apr 25, 2010 | GE WBSR3140DW Top Load Washer
Washer will not complete spin cycle
sound like solinoid has gone out
Aug 10, 2009 | Washing Machines
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Asko W600 spin cycle not working
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Sep 24, 2007 | Asko W640
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
