How can I screw the coin trip in property, it seems the inside piece have moved a little
Hi Karen,
I'm sorry to hear you're having difficulties with your Contrarotator. If you haven't got in touch with us already, I'd encourage you to give us a call free on 0800 298 0298, as one of our advisors will be happy to help you resolve this. Our Helpline is available from 7am until 10pm, 7 days a week.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
SOURCE: dyson coin compartment problem
try this push red clip up THEN turn to left the coin trap window,pull pipe firmly off from inside,clean gunk out,replace pipe pointing downreplace door by aligning notches turn to right 1 complete turn,if it feels tight turning TRY AGAIN until it feels smooth to turn.
SOURCE: open coin trap
use side of spanner to open the circular water drain plug on coin trap, remove all water.
use flat screwdriver to lift yellow tab at top of coin trap whiloe turning coin trap anticlockwise.
SOURCE: I start the machine, it runs till it would appear
disconnect machine from mains electric supply. remove top cover of machine then check the back of the control panel for a small black pipe, it should be attached to a small nipple in the panel rear if it is not you will get the fault you describe. if the pipe is connected remove it and blow down pipe with your mouth or a foot pump to remove any blockage then reconnect it and try the machine again. check also that the pipe is not trapped or kinked too i hope this helps you
SOURCE: dyson cr01 display said clean
check your outflow to make sure there is nothing inside it that can act as a blockage before the coin trap
SOURCE: how do I open the
Sorry to hear you're having difficulties with your Dyson Contrarotator.
It's probably best if you get in touch with us directly, so one of our
experts can run through some troubleshooting over the phone, and provide
the information and assistance you need.
You can call us free on
08002980298 - our Helpline is open from 7am until 10pm, 7 days a week.
Kind regards,
Jack
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and
the back feet are still on the ground.
Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom
right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have
towels ready. The next step you will
have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum
is a silver spring with a silver screw.
Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it
out.
6. Put the unit back together following the same steps backwards
