Question about Hitachi 53UWX10B 53" Rear Projection Television
No menu-pic pulled up on bottom and down on top
Cannot access menus and picture pulled up circular from bottom and pulled down circular from top - no adjustment - cannot converge colors - Was good pic but rained on trip here - plugged in before circuit boards dry. Some channels watchable and sound working. Made in 1991
    Genius:
  • 2,920 Answers
Take a blow dryer and blow all the boards dry..it should help some and make sure you get them completely dry
Posted on Oct 30, 2008
    President:
  • 2,712 Answers
Unplug the Tv from power source and undo all cables. Wait for at least 24 hours for the circuitry to dry well (or use a handryer in high heat on the back of the TV). After 24 hours, replug everything and see. If it still does not work properly, these settings can be adjusted through the service mode. All the available geometry and grayscale tracking adjustments are doneby manual controls located inside the set. They may be labelled.
WARNING!
Without proper documentation and training, you can probably do quitea good job of messing up your television set, perhaps even damaging it.
Don't mess around with the service mode adjustments unless you know what you're doing and have the service manual to guide you.
Once you enter service mode the first thing you should do is record all the original values BEFOREyou change anything! - This is the only way to restore the televisionto its original (factory default) state should it become necessary todo so.
If unsure, PLEASE call a service tech. Remeber, there are DANGEROUS voltages in the TV, even when unplugged. SO please do not attempt to open up the set if you are unaware, or have no experience.
Posted on Oct 29, 2008
  • 728 Answers
You might be experiencing a circuit board or electrical short since you did not let it dry before it got plugged up. Since water conducts electricity, when it got wet and you plugged it back up, electricity that is supposed to only flow through certain parts of the circuit board went over every part of the circuit board that was wet, causing it to short out and not to allow power past it no more to stop the tv from catching fire. You will need to get it checked out at a shop to confirm the suspicion and to get it fixed.
    Scholar:
  • 155 Answers
Check out.
  • fixexpert Oct 29, 2008
    it definately the problem of convergence in your tv main board and THE STK ICs needs to be replaced for sure
    if you have the technical knowlege and want do it your self
    click this link for step by step directions and diagrams
    http://home.earthlink.net/~oleg.filippov...
    thanks.
    Genius:
  • 1,913 Answers
Try to clean and dry the al ic of your tv.
also check power suplly earthig working properly.
reset your tv setings to deafults.
also replugs all cable connection after open the back cade of tv.
Posted on Oct 21, 2008
    Genius:
  • 1,550 Answers
I think you are getting partial power supply to circuit board .
    Genius:
  • 1,847 Answers
Well, the usual repair is replacement of the STK IC chips in the convergence circuitry. You can find many references to the parts and procedures on this by doing a google search or looking through the allexperts.com archives.
How to manually open locked door
First UNPLUG the WASHER.
There is a little white circle plastic lever that feels like an upside down lollipop about 2-3 inches below the door lock behind the front panel.. Pulling that down will unlock the door.
To access from the top of the washer remove 3 screws to the back top of the washer, push it back and then lift the top off the washer. Facing the washer slide your right hand down the space at the front corner where the lock is located. Feel around for the circular part at the bottom of the door lock and gently push it down. The door should then manually click and unlock.
To access from the bottom of the washer. Facing the washer, Remove the 3 screw to the very bottom that is holding the small access panel in place. This allows access to the bottom of the washer. Once removed, reach towards front and upwards to where the door lock is located. Feel around for a circle plastic level. Pull the level down. The door should click and you should be able to open the door.
Apr 18, 2014 | Maytag Washing Machines
Factory reset
In camera settings menu, on the bottom of the screen you find Settings. In Settings is the only reset the camera knows. You only will reset the menus and shooting options. Date, time, language and video output settings are not reset.
If your camera has serious trouble, accessing menus or something like that, there is nothing like pressing a button for several seconds and everything will be ok. (not in the manual)
Dec 08, 2013 | Samsung ES30 Digital Camera
Have bought a second hand philips 28pw6506, it has no remote control. Do you know how to change the aspect ratio or size of picture on screen? Have looked through the menus with the button on top of the...
Hello
To change its picture aspect ratio, you have to go to its menu. As you haven't its remote control there is an option for that, mentioned in its user manual. I hereby send it to you. Do the same and access the aspect ratio.
The television set has 4 keys which are located
on the front or the top of the set depending
on the model.
The VOLUME - + (- Vol +) keys are used to
adjust sound levels.The PROGRAM - + (- P +)
keys are used to select the required programmes.
To access the menus, simultaneously hold down
the VOL- and VOL+ keys.The PROGRAM - +
keys may then be used to select an adjustment
and the - VOL+ keys to make that adjustment.
To exit from the menus, hold down the 2 VOL-
and VOL+ keys.
Note: when the Child Lock function is activated,
these keys are unavailable
OK.
Dec 21, 2010 | Philips 28PW6506 28" TV
I have lost my instructions to my RCA LYRA rd1076, I have never used it so I do not know how to down load music. Can you please HELP!!!!
The best way is to use Cd's you have or buy. Use windows Media player or iTunes. To use Media Player, Start the program and looking at the top of the program, if the classic menu's are not showing - right click out next to the heading, Media Player, -> chose view -> then -> click on Classic Menus. This will show the menus that are easier to access. Now go to -> Tools -> Options And here click on the Rip Music tab. This is where you set up media player to rip music down to a MP3 and where to put it when done. So on this tab you will see Rip music to this location, Click the pull down and pick a folder you can find easy -(go to my computer, right click My computer and chose -> Explore -> you will see on the left side the folder tree, click on the ( C:\ ) at the top and open up the tree, then right click the( C:\ ) move to the menu at the top and chose -> New -> then Folder - then name your folder " AAA " it will always be at the top of the tree - easy to find), Tell media player to put your MP3's here, then move down on the RIP MUSIC Tab to the FORMAT section and pull down menu and chose MP3 => chose to rip when CD is inserted. click OK and close the Tools Menu, Close the Program. Now Hook up your player, go to My computer and see it you can see the player there on the tree, it should be at the bottom. Next insert a CD into the drive and when a window pops up asking what to do chose to RIP WITH MEDIA PLAYER. Once Media Player has finished riping the CD, G to your folder and Copy the MP3's into your player's Music folder - one at the time or as a group. Now you should be able to un-hook your player and enjoy you new music.
Jan 31, 2010 | RCA RD1076 MP3 Player
Hello kitty camera will only turn on when hooked to computer...help
Press the menu button and wait a moment. You will notice a flash icon (second icon in upper left). It is set to no flash by default (looks like a "no" circle with a line through it). Change to auto or always on or back to off by pressing the down arrow on the jog dial (circular dial).
Once turned on, you can press menu to enter the menu. Navigating the menus requires the manual a trial and error, but what I showed you above will get you going. I am trying to find the PDF manual (sakar has not posted and model 92009 support materials as of 1/1/10).
Note that I needed to install the software in order to pull pictures to my Windows 7 64 computer, but you may be able to just plug it into a Windows XP computer (although Windows 7 32 bit rocks, Windows 7 64 bit requires more work to get some 32 bit software working).
Hope this helps.
Dec 24, 2009 | Spectra HELLO KITTY 92009 1.1-inch VGA...
Important photos are stuck in the internal memory of my camera.
Select the Display mode with the top dial. Press the Set button to bring up the menus. Press the Rev key to scroll down through the menus. On the second page of menus, select the Copy menu. Then press the Lightning Bolt key to scroll right. Select the top of the 2 menu items. This will copy the internal pics to the memory card, assuming you have a memory card inserted.
May 27, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Cannot select "camera menu" from the Top Menu
If the camera is in Auto mode those items cannot be selected because the camera is already using factory default settings and they cannot be changed, If you press the Ok button and change to P mode then you will be able to access all of those menu settings and make any changes you wish to the camera settings.
Dec 28, 2008 | Olympus Stylus 850SW Digital Camera
Takes picture ok but no details on rear screen of anything menu etc.nor pics
Removed bottom cover had batts installed with plate on had general probe around found pcb made screen come alive but not working completely so gather fault is with pcb, sorry in is not a true fix but if new pcb fixes then I will let you know
Nov 08, 2008 | Pentax K100D Digital Camera
How do i delete pictures
DSC S700 Sony Camera:
To delete ALL pictures from the drive:
Click on menu.
Setup will appear near bottom of screen.
Using Joy stick (Round control on right of display screen)…..press right side arrow.
Several options appear. First..top…icon is a camera.
Click the bottom arrow on round control down one notch.
Format will be at the top of the screen now.
The yellow highlight will be on Create Rec. Folder.
Disregard this and click the right arrow on round control to the right one click.
Now …Format is highlighted.
Click one more time to the right….This opens up two options: Ok on the top and cancel on the bottom.
Highlight ok and press the center button on the round control. You will now be asked if you want to erase all the data on the memory stick. Click ok if you want to delete all.
You are now finished. Johnnie Harper....jshtxtrek@yahoo.com
Apr 27, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Front Load Washer Seal
you will have to take off the front off washer to put it back correctly.
remove the top panel 3 screws in top rear
remove the bottom panel 3 screw in bottom front
remove the top led control panel 3 screw or more along front lip
if you disconnect any wiring mark it well .
now the front of washer can be removed with or without the door (your choice)
careful with the door lock wiring.
be sure to unplug the washer.
while you are in the innards its a good time to wipe around the drum any buildup of soap etc..
and to clean the filter trap in the bottom access tube below drum.
Mar 31, 2008 | Maytag EPIC MFW9600S
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
