Back to:
Tags:
IBM 4230 Model 102 Matrix Printer
IBM 4230 with new printer board is printing...
posted by Sindarin on Jul 26, 2006
I purchased a new printer board for my IBM 4230-102 IPDS printer. The original board was giving a operator panel failure and we tracked back to a printer board. The board was easy to install. However when trying to print it comes out as gibberish, almost looks like a partially formed word. I had another board sent to me hoping that this other was broken, and still the same thing after 2 boards. I have checked all the settings and made sure they were exactly the same as all of the other 4230's here. I checked cables, tried another print head, and even placed the board in another printer and it still is doing the same. Has anyone run into this before?
Thanks
Sin
Comment by Sindarin, posted on Jul 26, 2006
p.s..all settings and operator panel works great, and the board works fine as far as connecting to the as400. It was receiving print jobs, just prints them in jibberish.
Comment by Sindarin, posted on Jul 28, 2006
I now took a similar model and disconnected the printer board and then re-connected it. It too is now printing in gibberish. Seems like either there is a setting that I am missing in the manual that needs to be enabled or a setup issue ie: cable backwards. Anyone run into this? Thanks Sin
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 27, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
if it prints, but it is gargabe, either the cable has a set of pins crossed or the Baud rate is incorrect on the card.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on IBM 4230 with new printer board is printing gibberish:
I don't want to Accept this solution
Can you Help with these Printers problems?
I bought a printer today. Its brand is IBM Inforint 1222....
Printer works for about 15secs then it stops and on screen...
getting error 055 what is the fix
after i print an invoice i can't get the invoice to...
My monitor is in half display.
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
