Sub woofer is popping and have lot of static - Audio Players & Recorders
    Problem Solver:
  • 4 Answers
This typically means that your voice-coil is fried (shorted) and the driver needs to be replace. I'm too lazy to read the terms of use so I don't know if I'm allowed to recommend a source. If you choose to replace the driver yourself it is a simple task. After disconnecting the AC power just remove the screws holding the driver in the enclosure and disconnect the two wires. On a high quality unit the wires will be soldered and it is simplest to cut them as close to the driver as possible - this leaves you plenty of wire to work with when connecting the new one.
Posted on Oct 21, 2008
Static on HK395 satalite speakers
It might be beacuse of some sort of wireless interference like a cell phone.
Mar 10, 2014 | Dell HK395 Computer Speakers
Ignition noise in the sub-woofer
Put a noise filter on the power input line to the sub.
Jul 10, 2017 | 2005 Toyota ECHO
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
My woofer and speaker make a lot of static and one speaker does't have any sound, it seems that when I move the blue connection the one from the speaker to the woofer the woofer gets louder and so does...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 29, 2011 | Boston Acoustics BA745 Computer Speakers
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I get a loud static noise, when I first turn on the yamaha ysp-1. Lasts a few seconds. Have unplugged all inputs. Problem persists.
u have a cool sound projector but u have a baaaad power supply system. bad power supply design - u will get all sorts of noise when u power it up. i have a sub woofer with the same problem(which in my case is the way it is designed). i used a delay circuit. but in ur case i know YSP-1 has a clean start up. so, if the warranty still covers it get it replaced. static noises, pop noises are often caused by bad capacitors.
Mar 12, 2010 | Yamaha Digital Sound Projector Home...
Driver side speaker and sub woofer make an popping
they could be blown try replaceing them and see if it helps
Jul 27, 2009 | Car Audio & Video
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Popping sound from sub woofer
disconnect the woofer and connect a different speaker see if other speaker makes the same pop if it don't then the woofer cone is defected if you have high watts and using stereo on high volume you can damage speakers.
Feb 08, 2018 | Yamaha HTR-5550 Receiver
96 people viewed this question
 Grubhead
Grubhead
