Question about IBM (25P3294) Motherboard
IBM motherboard, Rev 1.2, with an Intel 2 ghz processor: every time I reboot, a blank screen usually appears, with the msg: no operating system found. Only after repeated visits to the BIOS setup, and changing parameters, does it boot up normally. Why does this occur? Is it because of some soft/hardware conflict, BIOS. etc?
  • 781 Answers
Check the motherboard battery it could be flat and if it is BIOS is continually reset.
the Battery is a shiny round object about 19mm across and has a number on it only replace with correct number
The reason it eventually starts is the power gradually resets battery for a short while
Posted on Oct 23, 2008
What processors will are compatible with an hp 3396 motherboard
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source: http://browser.primatelabs.com/geekbench2/1112660)
Popular CPUs for this board are:
  1. Intel Core i5-3570
  2. Intel Core i7-377
(Source: http://openbenchmarking.org/linux/motherboard/HP/HP%203396)
Feb 25, 2015 | HP 339661-001 HP PCIx Cage DL760 G2 Mfr...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Sep 13, 2011 | Computers & Internet
I have an intel ibm rev1.6 motherboard am trying to
I am afraid that your motherboard type is available, but if you are not sure, don't worry, you can see directly from the net.. follow this link and place your mouse on the tools and select Processors and Motherboard compatibility.. good luck...
Feb 07, 2010 | IBM (02R4087) Motherboard
Earlier i had ASUS P5G-MX motherboard & 2.0 GHz Core 2 duo Processor.I upgrade my Motherboard to Asus P5KL-AM/PS & then i have a black screen with my 2.0 ghz processor, But i tried 2.8 ghz Core 2...
HI,
The only Thing To Do, is view both Motherboards, user Manuals.
To see The boards CPU Support List.
It could be to do with, certain Motherboards Supporting, certain CPUs.
I.e a 533mhz cpu, would not run on a Motherboard that supports 400mhz. The Systems Bios, May cause Other Problems.
If your getting a Black Screen, is it a possible Graphics/Ram Problem, Rather Than The CPU ??
Mike @ Compurepair.
Oct 22, 2009 | Intel Computers & Internet
Need a prossesor for motherboard
You can also use any other intel 775 socket processor as well. The dual cores are at the top of the list for performance that are compatible with that board, but if you're looking for a cheaper solution, I have that board with a 3GHz pentium 4 and it runs great. Here's a list of all the processors you can use.
Intel Pentium 4 (2.66 - 3.80 GHz)
(3.20 - 3.73 GHz)
Intel Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 2.80 GHz)
Intel 'Core' Celeron (1.60 - 2.40 GHz)
Aug 03, 2009 | Dell (E210882) Motherboard
I am from INDIA... i want to buy i IBM
Hi Friend,
Check below the model numbers of the intel dual core mother boards avaliable and the
address where u can buy it in Chennai,
1.Intel Atom 330 Dual Core (2x 1.6Ghz)
a.Intel D945GCLF2 mini-ITX
Features are:
  • Dual Core Atom CPU
  • TV-Out (S-Video)
  • 4x Rear USB 2.0
  • VGA, Serial and Parallel
  • 1x DDR2 533/667 RAM
  • 1 x Gbit LAN
  • Realtek High Definition Audio
  • Power: 24 Pin ATX, P4-connector
  • RoHS compliant
b.ECS P945GC
Feature are:
  • custom design board using mini-DTX form factor up to 170×170mm.
  • Intel 945GC and ICH7 chipset Intel Atom 330 CPU dual-core 1.6 GHz, 2×512KB (1MB) of L2 cache
  • FSB 533MHz system bus support up to 1×2GB (DDR2 533/400)
  • Integrated Intel Graphics Media Accelerator 950 ( GMA950 )
  • 2 X SATAII and 1 x IDE channel (for 2 IDE devices)
  • VIA VT1708B 6-channel High Definition audio CODEC
  • 10/100 Fast Ethernet LAN using ATHEROS AR8012 10/100 Mbps PHY
C.Jetway NC92-330-LF
Features are:
  • INTEL®945GC + ICH7 Chipset
  • Support INTEL®Atom Dual-Core 330 CPU
  • Built-in INTEL®GMA 950 Graphics Core
  • Supports 1x Gigabit LAN
  • Integrated ALC662 HD Audio CODEC with 6-CH
  • ITX Form Factor(170mm x 170mm)
  • Support Daughter board Expansion
D.Foxconn 45CSX / 45CTD (soon to be release)
Features are:
  • Intel® AtomTM dual-core 330 processor mounted on board
  • 533 MHz (FSB)
  • DDR2 533 MHz x 1 DIMM, Max. 2GB
  • 1* PCI
  • 2* SATA II
  • 5.1 channel HDA, Realtek® ALC662
  • 10/100M LAN, Realtek® RTL8100C
  • 6 USB 2.0 ports
These are available in India with Prices and best in India Industry
Intel Dual Core Price list in India
  • Intel E2140 Dual Core Processor - 2100/- Indian Rupee
  • Intel E2160 Dual Core Processor - 2450/- Indian rupee
  • Intel E2180 Dual Core Processor - 2800/- Indian Rupee
  • Intel E8500 Core 2 Duo Processor - 8200/- Indian Rupee
  • Intel 2200 Pentium Dual Core 2.2 GHZ -3400/- Indian Rupee
  • Intel E4600 Core 2 Duo Processor - 4990/- Indian Rupee
Address
Address:88/150.Nelson Manikam Road,Dharma Tower Ground,Floor7&8,Choolaimedu,Chennai-94
Landmarks : Near Nungambakkam RailwayStation / Loyala College /Metha Nagar Bridge/Opposite to Bank of Baroda/Mobile Store/ Indian Terrain Ready made
Contact Number:98402 72809
For future assistance kindly contact fixya
Regards,
Ayyasam
Jun 26, 2009 | Abit AS8 Motherboard
My system doesnt start
if no beeps (remove the RAM and for sure has to beep if the motherboard is OK) at all and no video signal you may look to:
1. a new PS - power supply or
2. a new CPU or
3. a new motherboard.
Jan 10, 2009 | Intel (SL5TL) Pentium 4, 2 GHz Processor
P5ld2-vm problem
go to "bios settings" by pressing "delete" key or F2 at the system start up time .. after going in to bios then search for the options load optimal defaults ....then save it and exit ..
after that restart ...
now have a check if your problem persists then the processor which you have choosed might not support the motherboard specification the frequency of the processor is higher than the specified rate .. check here for the details of the processor which supports your motherboard
Intel Core 2 Duo HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.L2 1102 2.00G HH80557PG0332M BX80557E4300 E4300 1.8GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.L2 1202 2.00G HH80557PG0412M BX80557E4400 E4400 2.0GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0492M BX80557E4500 E4500 2.2GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0562M BX80557E4600 E4600 2.4GHz,800FSB,L2:2MB,65W,rev.M0 1401 2.00G HH80557PG0642M BX80557E4700 E4700 2.6GHz,800FSB,L2:2MB,revG0 1401 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0362M BX80557E6300 E6300 1.86GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0364M BX80557E6320 E6320 1.86GHz,1066FSB,B2:4MB,rev.B2 1202 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.B2 0901 2.00G HH80557PH0462M BX80557E6400 E6400 2.13GHz,1066FSB,L2:2MB,rev.L2 1202 2.00G HH80557PH0464M BX80557E6420 E6420 2.13GHz,1066FSB,L2:4MB,rev.B2 1202 2.00G HH80557PH0564M BX80557E6600 E6600 2.40GHz,1066FSB,L2:4MB,rev.B2 0901 2.00G HH80557PH0674M BX80557E6700 E6700 2.66GHz,1066FSB,L2:4MB,rev.B2
check the website given below for details :
http://www.cpu-upgrade.com/mb-ASUS/P5LD2-VM.html
thank you
rate my solution
Sep 10, 2008 | ASUS P5LD2-VM Motherboard
IBM (25P3294) Motherboard Logo
750 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
